ajmartineau
ajmartineau
Washington
2021 Mach-E
A lot of newbies will get worse efficiency in one pedal or strong regen modes because they aren’t coasting enough and/or having to accelerate after braking too much.
1pt21Gigawatts
New York
2012 Toyota Camry
Architect
Curious, do electric cars with one-pedal driving automatically turn on the brake light when slowing down, or does it only initiate when using the brake pedal?
that’s a super cool and insightful question
JochemvRaak
Jochem
Tilburg, The Netherlands
Renault Kadjar
Sales Manager
It annoys me that they always mention the ambient light, since the select model does not have it. What a shame. :confused:
Are we sure it does NOT have the ambient lighting for drive modes? Other European models have it also standard.
Zandje
Netherlands
VW Passat GTE, MME AWD TP+ Lucid Red (2021)
The RWD models in Europe do not have the multi-color ambient lighting either
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
And you know that HOW? I have not seen anything to say that they haven't.
portlandg
grahame
Dorset UK
Cabinet maker
In the official brochure I've got from Ford, it says that ambient lightning is on the AWD model. It could be included in a technology package but theres no ambient lightning mentioned.
Interesting that you have a "brochure". All my efforts to get one have failed with only what is on the website available. FordUK have said that there isn't a hard copy available. Perhaps you could scan it and post on here for us to look at
Zandje
Netherlands
It is in the price lists for example in Netherlands and Germany. But saw it was not mentioned in the UK pricelist as an item.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Yes ... but.
If you listen to what Darren says, all three driving modes are similarly efficient. There may be some slight imperceptible difference. However, the driving modes tend to encourage different driving styles that may lead to differences.
For example, they have said the acceleration mapping in Whisper is much more gentle than in Unbridled. Whisper will tend to encourage sedate driving. In contrast, the immediate response of the accelerator to the pedal movement in Unbridled will tend to make you want that horse to run. That will be less efficient than the sedate driving in Whisper.
Sure; I'd bet the meaning is that all three modes are designed to be equally efficient from the engineering perspective. Thus if you drive the three the same you'll get the same range out of the car.
As pointed out by you, and others, however, the different "experiences" will tend to entice different driving "styles" some more aggressive than others which may have a larger affect on the overall efficiency than any design decisions in the car.
portlandg
grahame
Dorset UK
Cabinet maker
I suppose that makes sense. For some reason all the markets that Ford are selling this car in ALL have different versions and standards. Talk about confusing. Just hope that they get the spec right on the production line. I thought the ambient lighting was incorporated in the driving modes but have just looked on the US spec sheet I have and the Premium and FE have it listed but not Select/CAL R1. Ambient lighting is NOT listed on ANY of the UK versions according to the specs so it is either included in all or none have it. It sounds to me like it could be pot luck. Still not a deal breaker as far as I am concerned
Jolteon
Model 3
Tesla and Bolts do. I always assumed it was regulated.
Jolteon
Model 3
This is good news. I had been nervous that 1-Pedal Drive was going to be something you had to toggle in each key cycle. I'm glad I can lock it into 1-Pedal mode forever.
I also like that the Unbridled center display shows the actual battery %.
I was 99% sure I'd be driving in Unbridled (sound off!!!!!) before this, but now it's all but confirmed.
Jolteon
Model 3
Interesting, didn't think about a manual so I guess it isn't as bad as it sounds. We know the Mach-e will use the friction brakes to hold, so presumably the tail lights will be on. In fact current Ford cars, including Mach-E I think, has an auto hold. I tried it test driving an Explorer. Basically, once you brake and come to a complete stop, you can take your foot off the brake and the car will just keep you there. Awesome for the long drive-thru line at Raising Cane's. I think the Mach-E will have that option if you don't use 1-pedal, and I guess there really isn't a reason to not have it if you are using 1-pedal.
Yeah I think that's part of how our experiences drive the expectations.
I've never been a fan of automatics, and I came out of a manual into my Model 3, so the "engine braking" lift off seemed perfectly natural - as did the fact that you can override the Auto Hold and get the thing to roll backwards on hills/driveways if you feather the accelerator.
For someone used to an automatic, 1-Pedal will be a learning curve.
Looking at the Ford UK site, it seems like they have patterned the RWD after what would be called the "Select RWD" here in the US, and the AWD is is patterned after the "Premium AWD" here in the US. The wheels, roof, etc are identical to those models. Since it is likely that Ford wouldn't want to change more things than it had to when building the models for the UK vs elsewhere, it is logical that the UK AWD cars would have the same interior (including cabin lighting) as the "Premiums". What is more likely is that the UK website designer either didn't have the full feature list or simply missed putting it on the site.
silverelan
Seattle
2021 Mustang Mach-E GT
I'm relieved to see that Whisper mode is the equivalent to Chill mode in a Tesla. My wife really doesn't appreciate hard accelerations so this will likely be her default setting but with the sound on for auditory feedback (hopefully we can turn the sound back on in Whisper).
And when you do, it burns more juice. But if you baby it in Unbridled, it the same result as Whisper.
Yeah. Likes that's gonna happen ?
