AlpaChino
- JB
- May 4, 2021
- Indiana
- Mach-e Premium eAWD Ext Range, Rapid Red
I have a Grizzl-e EVSE with adjustable output between 16-32-40 amp settings, connected to a 50a breaker. I've used it at the 40amp setting for over a year with no issue.
About a month or so ago I ran into multiple charging errors such as "scheduled charge did not begin" or "charging stopped", typically only after 20-25 minutes of charging. The outlet is cool, the cords are cool, but the "nozzle" connected to the car is hot. Uncomfortable to touch the metal disconnect button.
I stepped down the EVSE to 32 amp and have had zero problems. There are times where I'm returning from a long trip and need to charge as fast as possible, so getting back to 40 amp is a priority.
My car will be getting BC at the dealer tomorrow. What other updates should I request that might solve this? Or is this a common issue that software won't fix?
