Would this work on non highway roads?Yes it should work. Make sure lane centering is turned on in cruise settings, and make sure you press the steering wheel button below the following distance button to turn it on. Engage cruise and you should see a blue bubble around the car when it's working.
My lane centerings works on regular streets without needing to be in cruise control. I have mine active at all times. It goes off and on at times depending on if it can get a good read of the lines but it works great. I keep it on by pressing the button to the right of SET -. When it's on you see two grey lines around the edge of the car, it's green when it's available and a line is orange when the assist is activated.Would this work on non highway roads?
Yes as long as there's at least one painted line.Would this work on non highway roads?
That's lane assist, not lane centering. They're different. Lane assist (green/orange lines) you will bounce off the lines. Lane centering (blue bubble) keeps you in the middle without bouncing off and requires cruise control. You need to be actively steering yourself unless you see blue. Blue is the color that means the car is actively lane centering.My lane centerings works on regular streets without needing to be in cruise control. I have mine active at all times. It goes off and on at times depending on if it can get a good read of the lines but it works great. I keep it on by pressing the button to the right of SET -. When it's on you see two grey lines around the edge of the car, it's green when it's available and a line is orange when the assist is activated.
