- Jim
- Sep 10, 2020
- Wayne, PA
- 2021 Infinite Blue Premium Mustang Mach E ER AWD
- Retied (formerly tried to herd highly technical, independent cats)
Ford has been building autos since at least the early 20th century. Ford’s have had fuel filler flaps since the 1960s (to the best of my knowledge, perhaps earlier?)
The charge port cover shouldn’t be some incredibly complex technological marvel, yet somehow, Ford has made it so. This morning, I walked into my garage and found my charge port door was magically opened, as if by elves, in the middle of the night. So, I go to close it and, as usual, it requires just the correct closing pressure on the precise point in the middle edge of the flap to properly engage the locking pin. Sometimes, for reasons unknown to me, it takes 3-4 tries before it closes. Supposedly, all this complexity is required because the locking pin engages a switch to tell the car when the charge port door is open so it can turn on the charge port illumination, light up the ring of lights and do other things. You mean to tell me you couldn’t have accomplished the same thing, using the fuel filler flap design from the Escape and a micro switch behind the hinge or something? Really? Every other Ford I’ve owned (and I’ve owned a few ?) have had fuel filler flaps that just closed by pushing them shut. They were spring-loaded and closed onto bumpers. No fancy switches or latches to engage. Sigh.
Moving on to the stupid DC charge PIN connector: instead of a rare earth magnet, why not spring-load this flap? I use it infrequently and there have been a couple of occasions when I’ve forgotten to raise it before closing the charge port door. Now, if Ford REALLY wanted to keep their mechanical engineers busy designing something super complex, they could design it so that, when you lower it, it latches, and when the charge coupler is removed, the latch releases and it closes the DC pins cover. Or a complex mechanism connected internally to the hinges on the charge port door that would pivot the DC pins cover closed if it was opened.
I know - first world problems. I would point out that very small details like these distinguish a true “luxury” car from a “premium” car. (Look at some of the things Lexuses or higher end MBs/BMWs/Audis/Volvos/Jaguars/Lincolns do)
