Locked out of my Mach E.
Jim McDaniell
James McDaniel
Oklahoma City
Mach E
On six occasions I have been locked out , I had both my fob and phone, I finely went around to passenger side and was able to open door. The next few times I was putting things in trunk and went driver side and it wouldn't open, I had both fob and phone. After a few minutes I was able to get in. The last time a was locked out I had to use to door code to get in. Has anyone had his problem?
Did you try pushing the unlock button on the phone or fob?
I've had that happen to me a couple of times with the phone and once with the fob (I rarely carry the fob). Pushing the unlock button worked for me.
The fob incident actually happened at the dealership when I went for my test drive. The salesman told me the Lincolns do that sometimes too.
Jim McDaniell
Jim McDaniell
James McDaniel
Oklahoma City
Mach E
Thank you I'll try it.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
I've had it happen as well. I've found if you press the open button 3-4 times quickly it opens.
Not sure if I'm freaking out the car or not but... LOL
You're probably one of those who presses elevator and crosswalk buttons multiple times, aren't you? ?
JamieGeek
Maybe, maybe not, you'll never know ;)
Just happened to try that once on the car and it worked so now I'm stuck ;)
Once so far. Came out of the store, opened liftgate with foot, put stuff on and closed it. Walked to the driver door and it wouldn't unlock. Finally pulled out the fob and hit the fob button. That worked.
Annoying.
TheSteelRider
United States
'21 Premium RWD
highland58
Seattle area
2021 Mach-E GT, 2023 Bolt EUV, 2018 F150 XLT
IT Solutions Architect
Annoying.
My Clarity is the same way. I can walk up to the locked car, open the trunk, then shut it, and the rest of the doors remain locked. It only unlocks the trunk. It senses my key fob and my hand on the handle to unlock. When I open a front door this way, everything unlocks. I can't just open a rear door that is locked, I have to stick my hand in the front door handle first to unlock all. I might be able to change settings to change that behavior, not sure.
My Escape has the same handle sensors (fingers inside the handle unlock it, button on the outsode of the handle locks it, all with fob in the pocket).
What you describe sounds normal. It was still unlocking the driver door as it should. The problem we're describing is where it wouldn't even open the driver door like it should. The proximity detection temporaily failed. Which (unfortunately) seems to be a common problem with PAAK (probably bluetooth not connecting fast enough). However I (and the OP) also had the fob with us, which should be 99.9% dependable. I have a suspicion that PAAK could be overriding the fob, but I don't really know. If it happens a few more times, I'll disable PAAK and see if it keeps happening or not.
Hplbiking
Hugo
Mustang Mach e
Emgineer
Every car we have owned can be finicky with the auto unlock. It's terrible on my focus electric.
AFVolt
Gene
Winter Haven, FL
Volt
Annoying.
I’ve experienced this behavior as well.
Loaded groceries in the back, closed the lift gate, and driver door would not respond until I used the key FOB to unlock.
Jim McDaniell
Jim McDaniell
James McDaniel
Oklahoma City
Mach E
Thanks it worked.
Keep us posted Tim.
SteveJo
Chadds Ford, PA, USA
2010 Ford Fusion Hybrid, Job 1 Mach-e/X
Off topic somewhat, but does anyone know of a door pillar code that opens hatch?
