phidauex
- Sam
- Dec 8, 2020
- Colorado
- 2021 MachE 4EX, 2006 Prius, 1997 Tacoma
- Renewable Energy Engineer
I noticed that wheel sizes are in a variety of locations and threads, so I'm compiling all the known sizes here. Let me know if you have a size I'm missing, or a correction.
value only = Confirmed from a printed Ford document or a photo from a user.
? = A reasonable estimate based on calculations or extremely similar vehicle.
= My wild ass guess, please confirm.
Stock Wheel and Tire Sizes
Offset range is believed to be 38mm to 53mm, which is believable given the stock sizing.
NOTE: "XL" in the load rating means the tire reaches maximum load at 41 psi, rather than 35 psi for SL (Standard Load) tires.
Wheel Weights
Gross Vehicle Weight Ratings
Curb weight is calculated (GVWR - max combined weight of cargo/occupants)
Lug nuts - M14 (14mm x 1.5mm), 21mm socket
Photos of wheel options
Other brand’s stock wheels that are known or suspected to work
Trim | Wheel Size | Bolt Pattern | Offset | Center Bore | OEM Tire Model | OEM Tire Size | OEM Load Rating |
Premium / First Ed. / Select 19" | 19" x 7.0" J | 5 x 108 | 47.5mm | 63.4mm | Michelin Primacy A/S | 225/55 R19 | 103H XL |
Premium “Summer Tires” Option | 19” x 7.0” J | 5 x 108 | 47.5mm | 63.4mm | Continental Premium Contact 6 ? | 225/55 R19 | 103Y XL ? |
Select / CA Rt 1 | 18" x 7.0" J | 5 x 108 | 47.5mm | 63.4mm | Continental Premium Contact 6 (Demos), Michelin Primacy A/S (US Selects) | 225/60 R18 | 104V XL (Conti), 104H XL (Michelin) |
GT | 20" x 8.0" J | 5 x 108 | 47.5mm | 63.4mm | Continental CrossContact RX | 245/45 R20 | 103H XL |
GT Performance Ed. | 20" x 8.0" J | 5 x 108 | 47.5mm | 63.4mm | Pirelli P Zero Elect | 245/45 R20 | 103Y XL |
Wheel Weights
Wheel | Wheel Weight | Stock Tire Weight |
18" Carbonized Grey (Select) | 25.6 lbs | 25.62 lbs (Conti), 26.26 (Mich) |
19" Shadow (Select) | 28.88 lbs (Conti) | |
19" Machine-Face (Premium, FE) | ~30lbs (weighed by member) | 28.88 lbs (mfg) |
20" Cast-Aluminum (GT) | 34.1 lbs (weighed by member, 61.1 lbs with stock tire) | 27 lbs (TireRack) ? |
20" Premium Forged (GT-PE) | 33.4 lbs (weighed by member, ~60.4 lbs with stock tire) | 27 lbs (TireRack) ? |
Trim | GVWR | GAWR (Front) | GAWR (Rear) | Curb Weight (stock) | Max Cargo and Passenger Weight |
Premium AWD ER | 5800 lbs | 2660 lbs | 3225 lbs | 4882 lbs | 918 lbs |
Premium AWD SR | 5500 lbs | 2570 lbs | 3020 lbs | 4617 lbs | 883 lbs |
Premium RWD ER | 5560 lbs | 2480 lbs | 3185 lbs | 4693 lbs | 867 lbs |
Premium RWD SR | 5340 lbs | 2420 lbs | 3040 lbs | 4435 lbs | 905 lbs |
Select AWD (19") SR | 5500 lbs | 2570 lbs | 3020 lbs | 4568 lbs | 932 lbs |
Select RWD SR | 5340 lbs | 2420 lbs | 3040 lbs | 4361 lbs | 979 lbs |
GT | |||||
GT-PE | 5980 lbs | 2805 lbs | 3260 lbs | 5068 lbs | 912 lbs |
- Jaguar E-Pace, 2018-2020
- Aftermarket spare tire, confirmed fit: https://www.macheforum.com/site/threads/spare-wheel-tire-at-home.6007/post-169380
- Jaguar F-Pace, 2018-2020 (confirm years?)
- 20 x 8.5 stock wheels, confirmed fit: https://www.macheforum.com/site/threads/jksu’s-premium-std-rwd-shadow-black-black-arrived-20”-jag-rims-added.3099/post-163247 and https://www.macheforum.com/site/threads/got-new-shoes-oem-wheels-from-a-jaguar-f-pace.5320/
- 18 x 7.5, ET45 stock wheels (10 spoke) are a confirmed fit, including the lug nuts. These just barely clear the Premium brakes. 24 lbs.
- Volvo XC60, 2010 to 2020, up to 20 x 9.0, not confirmed, but bolt spacing, center bore and offset ranges seem to be compatible.
- Link to a database of wheels that use the same bolt pattern and center bore as the MME. Width and offset are left as an exercise for the reader (from user cravacor): https://sizemywheels.com/lz-pcd/5-108?dia=63.4
