- Mark
- Feb 3, 2020
- Maryland
- GB E4X FE, Leaf, Tacoma, F-150 Lightning ordered
- Retired oceanographer
Here's a starting point on a checklist that I've been using on mine:
Mach E Checklist
External
Internal & Electronics Systems
Driving
Personalization
Other
Mach E Checklist
External
- Validate VIN
- Check every seam and door for alignment
- Open and close every door, trunk, frunk several times.
- Check undercarriage and all body/fascia edges for scratches or dents
- Check tire pressures and compare with tire pressure monitor
- Check lights, turn signals, etc
- Check headlight alignment
- Charge port and charge status indicator
- Check windshield washer fluid level
- Check windshield wipers and washers
- Inspect mirrors
- Fold and unfold mirrors, checking for noise
- Check puddle lights
- Check glass roof & margins
- Check all windows
- Check front license plate holder
- Check frunk divider installation
- Remove the rear luggage compartment cover
- Check brake fluid level
- Check coolant level
- Ensure the mobile charger is in the trunk
- Test mobile charger
- Ensure tire inflator kit is in the trunk
- Check seats
- Test seat headrests
- Test rear seat unlatch/latch
- Test controls on automatic front seats (and manual passenger in Select)
- Check interior door panels
- Check headliner
- Check all interior lights
- Check glove box
- Raise and lower all windows a few times from driver controls
- Raise and lower all windows from local controls
- Insert and remove every seatbelt several times.
- Check tire inflator kit age in infotainment screen
- Turn on the music to check it works
- Test Qi (wireless) phone charger and USB ports
- Test 12v outlets
- Driver Display whine?
- Is battery at 100% State of Charge?
- Reset EV range and trip odometers (Settings > Vehicle > EV Driving History Reset.)
- Check the center console is working in both dark and light modes
- Check screen responsiveness
- Reset the Sync4 (Volume down, right seek arrow, hold for 10 sec. why? just for fun?)
- Run Bezel diagnostics (Radio on AM or FM, Volume down, left seek arrow)
- Check A/C, heater, defroster
- Test keyless entry and start codes from card
- Program the passcodes for door and car start right there
- Sign onto FordPass and make sure the car is synced with that
- Pair phone using bluetooth
- Check backup, 360 cameras
- Test Navigation on screen and voice command
- Activate modem
- Test radio, Sirius, streaming
- Test Apple Car Play / Android Auto
- Check sound in all speakers
- Test seat heaters, steering wheel heater
- If the car was built before 1/9/2021, has it been tested per https://www.macheforum.com/site/thr...software-calibration-update.3364/post-106046?
Driving
- Test Cruise
- Test Adaptive Cruise
- Test Intelligent Cruise
- Test lane centering
- Test hands off wheel warning
- Test blind spot sensors
Personalization
- Adjust the seats
- Adjust the steering wheel stalk
- Adjust the mirrors
- Ensure phone as a key works right there
- Ensure key fob works
Other
- Check owner publications and keyless entry codes
- Run through my financing spreadsheet, verifying each item
