TheVirtualTim
- Tim
- Oct 11, 2020
- Dearborn, MI
- Mach-E First Edition, Escape Hybrid
Thanks for that report!
I like PlugShare to locate chargers and especially to read comments to find out if the charger is working/reliable. I don't like PlugShare for trip planning because I find it rather tedious.
I do like ABRP to get an idea of route planning ... but it doesn't have real-time access to the car state of charge (there is an option to upgrade to their premium tier and if you have a compatible BlueTooth ODB port adapter it can read that -- but I found the software wasn't very reliable and drained my phone battery very quickly and it also crashed a lot -- so I stopped using that feature and cancelled my premium tier. It's been probably about 1.5 years since I did that so possibly they've improved it by now.)
When I'm in the car ... Apple Maps _does_ have access to state-of-charge. For short-ish trips (not long road-trips) I sometimes use it.
But my all-time favorite is the built-in trip planning in Ford nav. It not only chooses good charging locations, AND it will dynamically update them if needed, AND if you open the trip details, you can tap on any charging stop and there's an option to let you select a different charging stop. I've had it suggest an EVgo charger, but I could update it to switch to an Electrify America location which was only slightly farther (and still easily in range) because I had charging credit available that (at the time) I hadn't expended. I had to play with the user interface a bit to get the feel for how to do it, but once I learned the trick, it's not too difficult. You can also do the route planning on the phone and then push the saved trip to the car.
