harrysiii
- Harry
- May 13, 2020
- New Hampshire
- '21 MME GTPE DMG; '18 Pacifica Limited
I'm getting a feeling this might be wrong, but the latest Tech Specs lists the GT as having (quite a bit) less cargo space than the rest of the extended range models. If this is accurate, the only thing I can think of is the suspension (correction, I just remember probably the biggest factor is the larger motor and anything that goes along with that). Any other ideas? I'm pretty sure all of the specs in this sheet for the brakes are wrong too, because I thought we found out it was misspoken and the GT actually has 16.1" rotors in the front? If they really do have 19" rotors in the front, that pretty crazy/amazing! So much for me trying to buy a 19" winter wheel/tire setup!
What's also interesting here is the "Behind Rear Seat" cargo space is the same for GT and GTPE, but the "Behind Front Seat" is greater in the GTPE than the GT, but is still different than the other models. Oh wait -- The GT must be a typo, too, and should be 59.7 (same as other models) because the measurement in liters matches the others. So maybe suspension in the GTPE does take up more room?
