Gino_A
- Gino
- Sep 30, 2020
- Fremont, CA
- 2019 Bolt, 2021 MME 2021 Pacifica, 2011 Silverado
- Retired
Today I accidentally tore off my Mach-E charging door after failing to get "Plug and Charge" to work, totally my fault. I went to a nearby EA charging station at my local Walmart. I plugged the charging plug into my charge port and after a few minutes, the charger instructed me to remove the plug. I tried this a few times and same result. I tried calling the EA number on the charger but could not get through. I went inside my car to try to call FordPass for help. After trying to find a number for FordPass I decided to just go home and troubleshoot my issue there. I backed out and heard a snapping noise. It turns out that I had unplugged the charging plug as instructed but left it hanging on the charge door. I felt really stupid then and still. I am posting this hoping that nobody else will experience my f-up.
Also, as it turns out, I had not completed the last step to enable the Plug & Charge FordPass activation process. Plug and Charge worked fine after I toggled it on in FordPass. The lesson here is to read all instructions carefully.
