Mach-E not charging to setting
acoots
Rock Falls, IL
Mustang Mach 3 2021
I recently changed my charging setting from charging to 70% to charging to 90% while plugged in at home. But it will only charge to 88%.
Anyone else having a similar issue?
Thanks in advance
cujo70056
Darryl
Menifee, Ca
MME gt
Maintenance
I have the same issue, I read to delete the location (ie home) and redo, haven't had a chance to mess with yet
ChuckA
Chuck
North Branford, CT
ā€˜21 MME Premium AWD ER in Infinite Blue
Accountant-Retired
Thanks in advance
I once thought I had this problem but then noticed that on the FordPass app the Home page had different info then the Vehicle page.
Seems that Vehicle page updates before Home page, so I was at 90% although Home still showed 88%. So my problem was I had no problem.
acoots
Rock Falls, IL
Mustang Mach 3 2021
Hi ChuchA,
When I get in the car, my actually % on my dash shows only 88%. That is also was is showing on my app as well. I feel like I still have a problem.
Hi ChuchA,
It probably stopped charging at 90% and then dropped to 88% by the time you got in the car. BMS will update % based on temp changes or after cell balancing. Since you normally only charge to 70% it will take a few days for the balancing to adjust to being charged to 90% daily instead of 70%.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Hi ChuchA,
Are you preconditioning the MME after taking it off the charger? Youā€™re correct that my suggestion doesnā€™t apply to your situation but to be within SOC 2% is curious.
acoots
Rock Falls, IL
Mustang Mach 3 2021
Today is charged to 89%, so I'll wait a few more days to see if it will reach 90%, but that seems odd that it would not charge to exactly what you want it to. When I want to charge to 100%, it always charges to 100%. Sorry, but I'm not familiar with what preconditioning is after charging.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
It means using remote start from the FordPass app and running the MME for 10 minutes (or less) without being plugged into the charger.
Iā€™m set to charge to 90% at home. Sometimes I see 89, sometimes 91, rarely 92. Rounding, overshoot, temperature fluctuations, etc. I donā€™t worry about it.
