Mach-e won't shift out of park
Robertwaller
Robert
Georgia
2023 Mustang Mach-e
2023 Premium extended range. It's happened twice this morning. Both times I switched the car off, got out, locked the car and walked around it once. When I got in again it shifted into reverse and later drive just fine. Any thoughts on the problem/
Thanks,
RLW
DaMeatMan
Toronto, ON, Canada
Thanks,
RLW
This may sound like a silly question, but was your foot on the brake?
Whoosahh
O
2022 Ford Mustang Mach-e
Are you using your PAAK?
Red Hawk
Cheryl
Massachusetts USA
21 Mustang Mach-E AWD Premium
I have a 21 Premium ER AWD. Here's a couple scenarios that I've run into. One is that I noticed the Parking Brake is engaged because on the small display, near the "Ready" it shows "Brake - Ready". I have to touch the accelerator pedal then we're ready to roll. Second, super easy mistake to make is to try to shift out of Park before the car has run through its powering on cycle. Give it a few seconds for the software to boot and cycle through POST (power on, self test.) Remind yourself it's a computer that you drive!
Hope that helps!
sgriffin130
Thompson Station, TN
'22 Red Mach E- C/T Pkg, '23 Escape PHEV/Prem Pkg
Dentist(retired)
Maybe even sillier, but was a door ajar? Didn't happen to me on my Mach E but did on my wife's Escape PHEV. I was confounded until I figured it out.
Robertwaller
Robert
Georgia
2023 Mustang Mach-e
I wasn't using PAAK and The door was closed. Ford tried to install the software update Friday night and it didn't complete for some reason. The upgrade was installed last night and the car worked fine today. Who knows?
Thanks, I appreciate the responses.
RLW the responses.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Thanks,
RLW
Hi there, I'd be happy to look into your Mach-E concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Joshj25
Joshua
Va
2024 mach e premium
Thanks,
RLW
We have a 2024 premium standard range And having the same issues.
We had it towed. The service department told us was because there was an update but now it's happened two times. Since then, start the car and the transmission won't move from Park.
Unfortunately it feels like the game's about to be well. We don't know what's wrong with it here. Take it back! + And hope we don't keep complaining about the issue.
Space_Pony
Indiana
2023 Premium Mach-E awdX
Wondering if this could be LVB issues. How much are you driving daily?
Thanks,
RLW
Early 2021 Mach Es had a problem in the short wiring harness that connected to the main drive unit. It had an intermittent failure that would cause the car to get stuck in park. The solution was a recall of that harness.
I'm not sure if this could apply to 2023s or if the parking pawl system had been changed by then.
Joshj25
Joshua
Va
2024 mach e premium
About 60 miles 5 days a week. Drove fine for two weeks and now nothing but problems. Still having anybody from Ford reach out to saw the level 2 charger either.
