- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Figured I'd make this topic to share my cold weather testing data this winter. It's going to be below zero Fahrenheit here on several days this week, and I'm sure there will be much more this winter (lowest we get is about -25ºF). But I wanted to offer to test things that people are interested in with the cold weather and share the results. So if there's something you wanted me to test in cold weather, let me know and I'll see what I can do.
Index of Tests:
Current conditions:
No Preconditioning Trip
Here's a trip I took last night to look at cabin temps. I started with a cold car in my garage, no preconditioning whatsoever. I drove a loop with mixed highway and interstate driving. 2022 ER AWD.
12/19 Trip Summary:
Outdoor temp: -2ºF/-19ºC
Wind: calm
Distance: 89.3 mi
Duration: 83 min
Displayed efficiency: 1.9 mi/kWh
Average speed: 65 MPH
Preconditioning:
NONE
Starting conditions:
Cabin temp: 29.3ºF
Battery temp: 30.2ºF
Displayed SoC: 70.5%
kWh to empty: 48.956
Ending conditions:
Cabin temp: 64.4ºF
Battery temp: 33.8ºF
Displayed SoC: 8.5%
kWh to empty: 8.226
Calculated stats:
Battery used: 62%
Energy used (BECM): 40.73 kWh (this is too low due to BMS drift)
Calculated efficiency: 2.20 mi/kWh (based on above)
Calculated efficiency: 1.85 mi/kWh (based on wall)
100% range at -2ºF: 144 miles (52% of EPA)
100% energy available: 78.6 kWh
Charge back energy:
53.3 kWh from wall
91.5% charging efficiency
48.8 kWh estimated to the pack
HVAC set to 68ºF AUTO 1
FYI my temperature sensor was placed on the passenger seat just under the headrest. It wasn't the best placement so it probably had a bit more thermal lag due to the seat in close proximity. So in reality the air temp was a bit warmer than the temp sensor showed. I will work on a better sensor solution for future drives.
Notes:
I drove an out and back leg from my home to the interstate, so there's a mix of highway and interstate driving. No wind, almost no traffic, perfect test conditions. Temps variable from -4º to 0ºF. BlueCruise at 75 MPH on the interstate.
The whole car/battery started at about 29ºF in my garage, I got in and drove with minimum idle time beforehand. Within several minutes the windows were already fogging up badly, I had to use MAX Defrost to clear them, which worked well. The initial humidity in the cabin was very high for some reason which caused fogging, even though I had dry feet and mats. Potentially there was some moisture in the A/C core that took about 30 minutes to purge. It took about 30 minutes before I felt "warm enough" while driving, the rest of the time I was slightly chilly but acceptable (wearing a jacket). Throughout the drive, the windows periodically fogged up a little bit for only a couple minutes at a time before clearing up. It was obvious the fresh air damper was opening and closing, when closed the fog would form very quickly. You can see the humidity spikes on the graph when the damper closed.
On the interstate the pack actually cooled down a few degrees to a low of 28.4ºF. Interestingly, the split between minimum cell temp and maximum cell temp increased with time. The coldest cell was 26.6º while the warmest was 39.2º, a difference of 12.6º. At the end of the drive I saw 32/50ºF, a difference of 18ºF or 10ºC.
Slowing down with 1PD I was shocked at how much regen the car allowed with a pack below 0ºC, I saw up to 75 kW. That's crazy high and really not good for the pack because of the lithium plating risk. The regen limit was adjusting with pack temp, but I'm very skeptical that this is an acceptable amount for pack longevity. Teslas will have almost no regen when the pack is below 0ºC but I was getting almost the full amount here. Maybe the battery engineers know something I don't, but this was my biggest concern/finding of the drive. The battery temp also rapidly increased after regen events, the cells don't want to accept all that power so a lot of it gets turned into heat. Regen is why the pack temps went up at the end of the drive.
The navigation said I wasn't going to make it back home and wanted to add a charging stop, but I made it back with 9%. I was targeting 10% arrival, so I was close. The recorded mileage was also slightly less than what Google Maps got, that's probably nominal. There is also an efficiency discrepancy with the "This Trip" screen for some reason. I get 2.2 mi/kWh from the raw battery data but the screen said my trip was 1.9 mi/kWh. Not sure what's up with that. The overall efficiency and range performance was about what I expect for these temps (getting about half of the EPA rated range). With a full battery my actual range would be less than 150 miles with the extended pack.
Findings:
Index of Tests:
- No Preconditioning Trip (Part 1) - #1
- Short Notice Preconditioning - #46
- Cabin Warmup speed comparison - #56
- Preconditioning Trip (Part 2) - #76
- 120V Battery Heating - #99
- 120V Departure Time Preconditioning - #101
- Idle Reserve Capacity Test - #126
- 120V Charging/Heating Test - #128
- Turning off HVAC to Heat Battery - #134
- En-Route Battery Preconditioning for DCFC - #138
- Battery Heating Time Chart - #142
- Reflectix Panoramic Roof Insulation Test - #147
- Warmer En-Route Preconditioning Test - #160
Current conditions:
12/19 Trip Summary:
Wind: calm
Distance: 89.3 mi
Duration: 83 min
Preconditioning:
NONE
Cabin temp: 29.3ºF
Ending conditions:
Cabin temp: 64.4ºF
Displayed SoC: 8.5%
kWh to empty: 8.226
Calculated stats:
Battery used: 62%
Charge back energy:
53.3 kWh from wall
Notes:
Findings:
- The heater was pegged at maximum output the entire drive (about 5.4 kW)
- The battery was never heated the entire drive
- The battery didn't really warm up while driving (except from regen), it actually got a couple degrees colder on the interstate.
- Regen limit with a freezing battery was astonishingly high at 75 kW!
- Significant cell temperature variations can occur in the pack after driving, this is also not very desirable.
- The HVAC system closes the fresh air damper periodically to increase heat, but the cabin humidity spikes and windows fog.
- Initial humidity in the car can be an issue, it took about 30 minutes for the cabin to dry out.
- Cabin temperature was very slow to rise, takes at least 30 minutes for the cabin to warm to an acceptable temperature with no preheat.
- The navigation estimate for arrival percentage is off, about 10% error in the conservative direction.
- The efficiency calculated by the trip computer does not match the energy used data from the pack (1.9 vs. 2.2 mi/kWh).
- The actual range and efficiency is about what I would expect in sub-zero temps.
- The trip mileage is slightly low compared to Google Maps.
- The cabin heat is pretty much at its limit around 0ºF. Window fogging and cabin comfort will likely go downhill from here as it gets colder.
- Wet feet and/or snow on the floor mats will increase fogging considerably.
- The new HVAC calibration helps improve heat but is still a bit chilly when below 0ºF.
- Trying to use recirc is out of the question at these temps, the windows will fog up almost immediately.
- I'm very concerned about the regen limit being so high with a cold pack. This could permanently damage it. Tesla does not allow virtually any regen at the same battery temps. It should be limited to 20 kW or less with a freezing pack IMO.
- Preconditioning to warm up the battery is highly recommended to prevent pack damage during regen.
- The trip computer and navigation seem to contain moderate errors in the conservative direction.
