Missing Promised Features/Software Bugs
kdryden99
Richard
Montreal Canada
Last Updated: March 8, 2021
Note: see also Mach-E Issues List | Ford Mustang Mach-E Forum which is issues, vs. "missing" features or desired changes.
Features that were promised, or we'd like to see, that aren't there yet:
  • Door supercapacitor
  • Frunk Open with FOB or Phone
  • Rear ambient lighting
  • Charging Schedule (not working, issues with locations, very limited options) Ford working on it, confirmed by @Shayne. When plugging in EVSE, schedule is not respected, charges to 100%
  • Pre-Conditioning (limited options)
  • Mute and Source buttons not working
Note: also see:
and, the joke thread on this:
Anything else? please chime in will update
TheSteelRider
United States
'21 Premium RWD
I want to make a list of features that were promised but not working or not available
-Paak (needs work)
-WiFi connectivity (needs work)
-Door Capacitor (unverified)
-Automatic Profile from Drivers Seat (not working)
-Garage Door Opener (loses connection)
-Android Auto (waiting Google fix)
-12V charging while plugged (unstable, needs work)
-Charging Schedule (needs work)
Shrimp, wings
CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
Rear row led ambient lighting and two-toned steering wheel.
Woeo
Woeo
Fusion Energi
-Paak (needs work, doesnt work or too sensitive)
-WiFi connectivity (needs work, seems very picky with ssid)
-12V charging while plugged (unstable, needs work, doesnt charge properly )
-Charging Schedule (needs work, issues with locations, very limited options)
-Pre-Conditioning (limited options)
-Charging Curve (needs wor)
-Charger compatibility (Charging stops on fault or very slow)
-Charger payment (often fails)
Electronic frunk release from fob and phone
Rear seat ambient lighting
kdryden99
Richard
Montreal Canada
I cant really add those since therent really promised, i understand what you mean though but I want to only mentions that were explicitly mentioned
CHeil402
King of Prussia, PA
Electrical Engineer
It's shown in the gallery of the product page and on the car's menu
ARK
Los Angeles
Mustang Mach E
To be fair, many of the items listed are not so much ‘missing’ as opposed to having issues that are likely to resolve.
kdryden99
Richard
Montreal Canada
True its a mix of both
  • Like
Reactions: ARK
RyZt
San Jose
Mach E4X
To me, instrumental display electrical whining and wind noise from glass roof are the two biggest issues. Surely everyone has different priorities.
Ford may be able to tune it. But I don't think it's realistic to expect it to work much better. I think there are technical restrictions there. If you expect it to work as well as key fob, you will be disappointed. If that's what you want, use the fob (and buy a 2nd one if you need two).
I refuse to carry keys, and would be fine using PIN code to enter and drive exclusively. (I use Nest x Yale lock for home, which can be unlocked with either PIN code or through a button in app. I use PIN most of the time, because that's faster than unlocking from the app.) PaaK is more convenient than using PIN code, but I don't mind falling back to PIN code. So PaaK has met (or exceeded) my expectations.
  • For entry, PaaK works reasonably well for me.
  • For starting the car, the car often can't detect PaaK when the phone is in my pocket when I sit in the driver seat, which reminds me to put it on the charging pad (and therefore isn't too bad).
Android Auto is fixed, if you are tech savvy enough to install the next version before Google rolls it out to 100%. If not, well, multiple people including me have verified that the next version works, so all you need to do is wait a week or two.
Works perfectly with my 2012 model LiftMaster. If your garage door opener is very old, it is well known that HomeLink may have compatibility issue with it. There really isn't anything Ford can do here. You may be able to buy a bridge that would resolve your issue.
trutolife27
Bourbon Country.
-Frunk Open with FOB or Phone
-Rear ambient lighting
not really missing just need some updated to fix. On the steering wheel, yes I wanted the white also but it did not make it to production. So it wouldn't fit also.
