MarknKC
- Mark
- Jan 30, 2021
- Kansas City, Missouri
- 2021 Mach E Premium
- Electrical Engineer
Just thinking out loud. There seems to be issues with temperature and LV battery. You "tried it a few times and it finally started." Current flows, things heat up, and finally the car starts. It might be as simple as a frozen battery not able to supply enough current to engage all the systems. Repeated tries heat the battery. The battery heats and supplies more current (amperage). Finally after enough attempts, the battery heats itself to the point where it can supply enough current et voila !
If that is indeed what is happening, this issue should start disappearing in a few weeks. It still needs to be fixed of course. Hopefully there are already enough sensors in the vehicle that will allow this to be a software fix.
