blue92lx
- Adam
- Jun 13, 2021
- Florida
- Ford Fusion
What's crazy to me is that without brake launching the 1ft roll out is the same as a brake launch.Correct. So, by not brake-torquing it took you .52 seconds to hit the 1 ft. Roll out! An eternity. So, the 3.67 looks good but the reality is it took 4.19 to actually hit 60 on that run. And it was obvious on the G trace with a super slow ramp up. Usually it’s .2-.3 secs.
So, there is the additional .2-3 secs you can take off your next 0-80 run. Brake-torque it!
Which is interesting because that means essentially you have the option to slam power into the motors right at the beginning and it tapers down quicker, or it has a slow buildup to a high power level and then tapers down.
Because if the power curve was the same on both then the 4.2 second run should have pretty much been a 4 second with 1ft rollout.
If that makes sense.
