Mirak
- Oct 8, 2020
- Kansas
- "Sonic" 2021 MME Grabber Blue First Edition
After my OTAs stalled out on 2.4.2 over a week ago, I got approval to have the dealership install the BlueCruise update yesterday. So I think that makes me one of maybe a few dozen Job 1 2021s that actually narrowly got BlueCruise by the end of Q1 2021, though not OTA. And about 9mos late as originally scheduled, but I digress. What you guys want to know is how it works.
Well, first, be aware it may not work at all for the first 12-24 hours! Even though I had it toggled on under the driver assistance settings (it’s called “hands free”) and I checked my ford.com vehicle dashboard to ensure BlueCruise was activated (under Connected Services), it didn’t work for me last night. Customer Service was worthless, as per usual. They suggested I wasn’t on an eligible road. When I asked them to verify based upon my location, they said they couldn’t do that because they don’t actually have a map of the Blue Zones. One is supposed to be coming. In May. Dammit Ford, stop being so bad at this. Please.
But anyway, today it worked. I took it on about a 25 mile loop of a few connecting highways around and through Wichita. It generally works fine. I had no issues on the straight stretches - no ping ponging - and it also handled most of the mild curves with only mild ping ponging.
In the map below, I’ve highlighted three curves in red which it could not handle. Well, let me be very clear about this - the lane centering could handle these curves just fine, but BlueCruise insisted that I put my hands back on the wheel anyway. And it does not navigate highway interchanges at all. I’m not talking cloverleafs - it cannot even handle gently curving 60mph ramps from one highway to the next.
When BC is operational, the eye nanny is very sensitive. If you look down ever so slightly at the IPC (driver instrument panel cluster), you will get a gentle “Watch the Road” pop up (no chimes) after 5 seconds. If you you look over to the infotainment screen or up to the rearview mirror or off to the side somewhere, you will get a stronger “Watch the Road” (with chimes) after 5 seconds. In either case, if you ignore that warning for 7 seconds you will get a “Resume Control” and louder chimes. I didn’t see what happens after that.
So that’s basically it. My assessment is that BlueCruise is currently very conservative. I can see how this will be a bit more relaxing on long drives (I’ve got a two hour highway trip coming tonight), but at this point I’m not sure I’ll continue past the 1yr free trial unless Ford loosens up on the reigns a bit. I don’t mind the sensitivity of the eye nanny - that part wasn’t the nuisance I feared it would be - but with the amount of times you have to put hands back on the wheel it’s not a massive enhancement over standard CP360.
Let me know if you all have any questions.
