My GOM is very optimistic this morning!
EasyPass
2021 MME Premium 4X, 2017 Fusion Energi PHEV
Premium AWD Ext Range
56 degrees/78% Humidity/Sunny/Mild Winds/High Barometric @ 8:28am
100% home charge overnight from 52% SoC
EPA rated for 270 miles of range
Delivered 8/25/21
Odometer 1,435
GW Shark
Larry
South Carolina
2021 Premium ER AWD Star White, 2014 Prius V
Scuba Instructor
I have the same vehicle. The GOM was generous to me also. It has gone as high as 322!
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
Lol I only charged my FE to 100% one time over the 10500 miles I drove it. It was by accident too. Second most was 95% before I took a road trip. I never saw the GOM go over about 290.
My GT GOM is super pessimistic. Like 190mi at 80%. I definitely am getting a lot better than that.
EasyPass
EasyPass
So today I traveled 118 actual ground miles (from Google Maps), but consumed 145 range miles (56% SoC at end) with a combination of 70% highway and 30% city/suburban. The differential of 27 miles is almost the same as the "extra" range that was reported at 100% SoC this morning. I guess it all evens out in the end when the GOM tries to do its thing. ;)
Interestingly, the Trip Odo reported 4.6miles/kWH. Quite high from my limited experience.
ARK
Los Angeles
Mustang Mach E
The 'range' miles are not fixed the way 'ground' miles are. What you experienced was really just coincidence. If your miles instead had been say 95% highway and 5% city/suburban, you would have done even worse. If, on the other hand, you flipped it and had done 70% city/suburban and 30% highway, the 'extra' range would not have disappeared, based on the results you are reporting with 70% highway and 30% city/suburban from your driving.
Side note, but I would suggest not charging overnight to 100% if you don't think you will need most of your range. From your two posts, it seems you ended the day with 56% SoC today and 52% SoC yesterday. Ford recommends you charge it no higher than 90% on a regular basis if you do not need the full range available in the battery, though I personally think you should go a bit lower if you plan to keep the vehicle a long time and don't need a full charge for maximum range.
AZBill
Rivian R1T, Hummer EV SUT, MME CA Route 1
I normally only charge to 80%, but last time I charged to 100%, I got this extremely optimistic result:
Ford Mustang Mach-E My GOM is very optimistic this morning! gom407
Today sitting at 80% it is showing 279 miles. I typically see it range from 240-290 when charging to 80% and just driving around town with some highway usage.
EasyPass
EasyPass
Today was not a typical day of driving for me. So far, lacking a long destination, I seem to only need a charge once a week or so for my normal activities on my home Level 2 50amp line using the supplied Ford Mobile EVSE. Would a top-off to 100% every 7 or 8 days make any difference in maximizing the long term battery life vs. only going to 80%? Are you saying use the Charge Scheduler to limit the top-off point on every charge session rather than let it run out on its own? I know that DCFC and the vehicle's internal charge curve kind of makes 80% a practical limit point on its own.
Occasionally, about 6 times a year, I do a 200 mile excursion to a public Destination Charge Port (Chargepoint 7kW) and then a return a few days later. Could a 100% top-off there be justifiable especially considering I also will do it in the dead of winter? TIA for the comments and input.
  • Like
Reactions: ARK
ARK
Los Angeles
Mustang Mach E
I am not sure how much of a difference your specific use scenario would make. Frankly, it doesn’t sound like a huge amount. However, the key is how much time a vehicle spends at max charge. Over a period of years, if it spends some meaningful percentage of time at 100% charge, this will hurt its max capacity.
Yes, I would suggest using the vehicles settings to limit max charge to something less than 100%. You set it once and never have to think about it again, and can manually tell the vehicle to charge to 100% through the FordPass App on the rare occasion where you need it.
I don’t think there is any issue at all with charging to 100% six times a year when you need it. The toll starts to get taken when you are regularly doing it, like 50 times a year when most of that time, you didn’t need anywhere near a full charge.
