We all have different boxes and expectations.I canceled my star white premium awd extended after a test drive. The test car was beautiful but the run had no seat of the pants fun. Perhaps Ill test drive a gt but I have no desire to own a car that doesn’t tick the boxes.
When did you buy your Grizzl-E? Mine was doing the same as yours. Regardless of whether it was charging or not, it would regularly go from blue to red and start buzzing. It would reset to blue by cycling the power cable. (Then as some point, go red again.) Temperature wasn't a factor with mine. It happened in cold or warm. According to one of the other threads, apparently they had a bad batch of some component.Grizzl-E has degraded to the point of being useless. My 32 amp portable charger works the charm. Working on resolving the issue with UnitedChargers but have yet to get a response to my email.
Thanks for sharing this, I will give them another day or so then send Anna an email. I think I spoke with her on the phone. It is a short week for them this week with Victoria Day , they are probably playing Monday catch up.When did you buy your Grizzl-E? Mine was doing the same as yours. Regardless of whether it was charging or not, it would regularly go from blue to red and start buzzing. It would reset to blue by cycling the power cable. (Then as some point, go red again.) Temperature wasn't a factor with mine. It happened in cold or warm. According to one of the other threads, apparently they had a bad batch of some component.
It took a couple of days for United to respond to the online request, but they very quickly sent a replacement unit that has worked flawlessly since.
Try [email protected]. She will send you the form to fill out.
There was an update to the charger that is/was downloaded during the setup process or later if it's still installed. That part they're correct about. Good luck with the negotiations.My Ford dealer just called and offered to sell me back my original charger in the box I brought it to them in all those months ago. Said they have a firmware fix and that it should work fine now. Debating attempting to get it at a discount. May call back and offer $400.
Went through that truck fest last weekend too. Crazy stuff.So just rolled over 4000 miles on our trip yesterday.
Here is the trip record info.
Started at 100%, 305 on the GOM, half highway, half surface streets.
Finished.
Rough numbers on the 4k miles fueling is $111 @ 11 cents/kw. @ 3.7 mile Kw . Fuel prices in the wife's Explorer for the same mileage would be over $550 and a $50 oil change.
BTW truck fest has traffic off the hook locally. Had one SOB hanging out his buddies 4x4 window talking smack last night. Just rolled up my window thinking "sure buddy, nothing says denial as much as pretty lights all up under you truck and fake testicles hanging from your receiver hitch."
