Robob
- Rob
- May 29, 2023
- Vermont
- 23’ GT Cyber Orange
- Auto Parts, Paint & Tech
Within the past few months in the retail and beta (test flight) versions of Ford Pass there seems to be a Bluetooth(BT) key / PAAK bug. I have posted this in other threads but I am making a thread for info so people don’t end up stranded by this randomly striking bug.
My car is fully updated in FDRS and iPhone 14 Pro is also updated fully to 17.5.1, app is now retail 5.0 version and have removed the beta versions. PAAK has worked great ever since I got the car almost a year ago with this same phone so nothing has changed other than updates.
After a random amount of time the PAAK key in app will just stay disconnected in BT status, the Bluetooth audio and CarPlay connections will work fine. But there seems to be no way to force BT to connect with a refresh, log out/in, reset phone, reset car, etc. Nothing will make it re-connect and you must use the backup password. Remote start and all other non BT functions still work in the app as well.
The BT connection with the last of the VIN + MACH E in the phones Bluetooth connections will not connect no matter what. If you search for connections after removing this you will see the car is still broadcasting the connection but the phone won’t validate and connect to it.
The only way to get it back is to reset PAAK in car settings/general, reset ford pass PAAK, then remove the BT connections in phone, delete and reinstall app and re-pair PAAK but it still happens randomly again.
Just FYI in case someone gets this bug, make sure you have your password set and test it regularly after car and app updates.
Do NOT delete the app or Bluetooth connections before getting to a key fob first. As once you remove the app the PAAK backup code can sometimes reset or not work in my testing until re-paired with the app.
I reported this each time it happened in beta and also in retail testing so hopefully a fix will come from ford or an iOS update soon. I also hope they add a manual way to force connect the BT key or even disable it if you are working near the car and don’t want to have it always connecting when you walk by.
TLDR- Ford Pass can randomly not connect your Bluetooth key, do not delete the app or Bluetooth connections until your back to a key fob. Then delete/reset in car and app, then re-pair PAAK. Always test your backup code after app and car updates.
UPDATE: After some testing this seems to be a connection limit time-out. Once you go over a certain amount of connection attempts without turning on or opening doors the car disables the PAAK device for 24hrs and then it will work again.
If you work near your car or walk by it multiple times a day make sure you turn off bluetooth or if you still need it for headphones etc try force closing the ford pass app as this seems to help (not sure if it prevents it). Still make sure your backup password works if using PAAK after every update for car and app.
