Litnerd88
- Teresa
- Apr 13, 2021
- Joliet, IL
- Mustang Mach E Premium with AWD and Extended Range
So the problem with why some Mach Es won't charge with the supplied evse plugged into 240 in Illinois is apparently because of an over voltage condition. There is no current fix for this through Ford. Our power measured out at 246v and it will not charge with the supplied evse. Has anybody who encountered this issue been able to use a wall mounted charger (charge point or the Ford one) at their home using the same power source? I understand that dealerships with chargers and power stations may have their own transformers that would supply the correct voltage so they would not encounter this issue. The mme evse plugged into our 240 charged our friend's Prius plug in hybrid with no issue so I know it is a problem with the Mach E and not the evse. Any insight would be appreciated.
