DevSecOps
- Todd
- Sep 22, 2021
- Sacramento, CA
- '21 Audi SQ5 / '23 Rivian R1T / '23 M3P
- CISO
Preface:
This thread is in regards to DTC P0C2A, P2796, or P2797, which is an oil pump stall. There's been a few reported instances on this forum, Facebook, and Reddit that I've seen. Additionally, I had this failure happen to me, 150mi from home on March 15th, 2023. It appears to be an emerging issue and one that people should be aware of.
What is P0C2A P2796 P2797?
This fault is when the oil pump in the transmission/motor fails, or stalls.
Can I have failure without an IPC warning?
Unfortunately, as of January 2024, Ford has decided to remove the SVS notification for some failures of the oil pump. The code is still thrown, however the vehicle shows no sign of failure on the IPC. The only other way to know if failure is present is through speed. If the code is present the vehicle will be limited to 87mph.
We have an oil pump?
Yes, we do! The oil pump, pumps oil through the motor and transmission step down gears in order to keep them lubricated and cool. Some vehicles such as Rivian, elected to go with a splash oil system where there's no pump and the oil just sloshes around inside of the transmission case. Others, such as Ford and Tesla decided to pressurize that system and push oil through the transmission.
- Side question - We have a transmission?
Yes, but not in the traditional sense of a transmission. The transmission of an electric motor is actually part of the motor assembly. It connects to the side of the motor and is only a couple inches thick on some vehicles and a bit larger on the MME. The step down gears connect to the stator within the electric motor and half shafts to convert the very high RMPs in the motor to the desired RPMs at the wheels.
What happens if we keep driving?
Driving with a failed or stalled oil pump can cause the gears to get damaged or cause overheating in the transmission/motor and could result in a complete replacement of the motor assembly.
How do I know the difference between this and HVBJB failure?
You don't - unless you pull the codes. The HVBJB failure can present itself in the same way as the oil pump failure in the instrument cluster.
How is it fixed?
The entire motor assembly has to be dropped and disassembled. The oil should be checked for metal flaking which could indicate damage to the gears. If no damage is present, the pump (LJ9Z-7P086-A - which ironically can be purchased at Walmart) will be replaced along with the possibility of inner bearings (LJ9Z-7118-D), nuts, bolts, and retainers. They will refill the system with transmission oil. In the cases I've seen where damage has occurred the entire motor assembly was replaced.
How long does it take?
It appears that this repair takes about 2-4 weeks depending on parts.
Failure of the pump aside, do I ever have to replace this oil?
Yes, per the manual you have to replaced the oil in each motor/transmission at 10 years or 150k miles.
What should I do if this happens to me?
I would recommend that you stop driving the vehicle and only drive it in emergencies or to the repair dealership. Immediately call Ford and open a case. If you are stranded call Roadside assistance. The numbers are below:
Ford Roadside (to get towed):
(800) 241-3673
Ford customer support (to get a case started)(only open M-F):
(800) 392-3673 - USA
(800) 565-3673 - Canada
Video explaining the oil system:
How is it fixed?
(800) 241-3673
