Utahridge
- Aug 6, 2021
- Michigan
- 2021 Ford Mach-E Premium 4x
My first thought was that I had interrupted the updating of the modules after starting the car.Order, at least of these two recent updates, seems to be irrelevant as they update different things (technically I think 1.4.0 would make since updates that were later superceded by 1.6.0 but from what I've seen, getting 1.4.0 doesn't walk back any 1.6.0 changes).
As far as scheduling, not all updates require scheduling, these will go through wherever certain criteria are met. Seems a lot of updates are getting pushed now, likely clearing up stuff before a bigger update .
As far as your warnings, my only guess is part of the install requires rebooting of various modules. Depending on when the install happened, the reboot sequence might have been interrupted, causing some modules not to report properly, therefore you get the warning light.
Advice would be to take to dealer, get it documented. I'd guess the warnings would all go away after a period of the car being shutdown, plugged in, and later restarted... But that's just a guess.
I hope the errors clear up in the coming days and I will try to get by the dealer to get the incident documented.
Thanks for the advice.
