imstriker
- Matthew
- Dec 4, 2019
- Indianapolis
- 2020 Jeep Gladiator, 2021 Infinite Blue
- Tech
I wanted to share how my personal experiences with PaaK have changed. I believe I have almost settled into a routine that might help someone. For techie and family reasons, I have been determined to use PaaK since day one exclusively. It has not been a pleasant process, but I have stuck with it and not brought a keyfob with me. That usually ended up meaning a lot of using backup codes, but recently that has changed. So, here is my current process after FordPass 3.24.0...
- Change location permission to all the time. Between this and 3.24.0 my chance of success each time has gone up considerably.
- Set FordPass to background battery restricted (thanks again to this forum). Yes, this has implications. However without it my Pixel 5 would die by 2-4pm every day.
- When unlocking car, pull out FordPass as I walk to it and unlock on app. Without background usage, this is necessary to unlock (without PIN) and to start the connection process.
- When in car, usually wait about 5-10 seconds before app changes to connected and start.
I give up unlock as I walk up and it is definitely not as convenient as a simple walk up FOB, but it is working. So far I have not had to use a backup code since going to this method. That is a huge improvement as I would have previously been at using a code 60% of the time. Hopefully Ford can find a middle ground on the battery usage issue and then allow background battery usage again. I have not been to the dealer to get the PaaK fix yet. I think I may just wait it out now since this seems reliable so far.
