Don't know if it's a physical limitation of the design (ie: for safety reasons), or only a limitation of how the software is currently setup and might change in the future, but... we know that when charging it doesn't charge the 12V battery. If you leave your car plugged in but never start it, your 12V battery will eventually drain.What about flashing modules while plugged into a L1/L2 EVSE? The car can condition the 12V battery during a charge session. And this is a more typical scenario for eventual OTA updates.
Maybe that's an unsafe approach for dealer service techs since they may be doing other work on the vehicle and needing to disconnect the HV battery? But most of the time they're doing one thing at a time (or at least, they are billing customers or Ford as though they only do one thing at a time).
That doesn't work because the car has to engage that charging on the 12v battery. It can't do that while flashing some modules. So they have the dealer plug into a battery charger while running the long updates.What about flashing modules while plugged into a L1/L2 EVSE? The car can condition the 12V battery during a charge session. And this is a more typical scenario for eventual OTA updates.
Sometimes FordPass lets me know that the 12V battery is being charged. When I notice this, it's usually this is in the first few minutes of an overnight charge session. So, maybe it can't charge the HV and LV batteries at the same time, but it can condition the 12V during a J1772 connection. (Or FordPass is displaying incorrect information, which also happens.)Don't know if it's a physical limitation of the design (ie: for safety reasons), or only a limitation of how the software is currently setup and might change in the future, but... we know that when charging it doesn't charge the 12V battery. If you leave your car plugged in but never start it, your 12V battery will eventually drain.
Wouldn't that suggest that OTA updates of large content that ultimately deliver to a module over a slower CAN type network can't work, either? This doesn't check out for me.That doesn't work because the car has to engage that charging on the 12v battery. It can't do that while flashing some modules. So they have the dealer plug into a battery charger while running the long updates.
They do, you won't. They'll also be able to easily replace any misplaced clips.Ugh, do they have to take off the panels under the hood to charge the battery?
Cold be something much more basic: a large download coupled with the desire to get the problem resolved sooner than a mass OTA rollout.Wouldn't that suggest that OTA updates of large content that ultimately deliver to a module over a slower CAN type network can't work, either? This doesn't check out for me.
Or maybe updates through the diagnostics port aren't able to be routed through the GWM? Seems like a bad limitation to me, but maybe it's just how it is for now.
You’re not supposed to update modules while the HVB is being charged. FDRS instructions says this sometimes. Sometimes modules that need to be updated are controlling the HVB charging process and it can’t be updated during charging. In the case of an OTA update they are able to test beforehand the exact length of time and how the update works as well as failure modes. This way with OTAs they know how much 12v battery power they need and how to tell if the battery is weak.What about flashing modules while plugged into a L1/L2 EVSE? The car can condition the 12V battery during a charge session. And this is a more typical scenario for eventual OTA updates.
From what others have posted about how the OTA's work, a lot of the modules have two memory banks in them. So an OTA will update to the backup memory bank, and then the next time it reboots, it will switch over to the newer programming.Wouldn't that suggest that OTA updates of large content that ultimately deliver to a module over a slower CAN type network can't work, either? This doesn't check out for me.
