louibluey
- Joe
- Dec 21, 2020
- NY
- FE "Louibluey" GB
- retired
UV ab - as predicted by @TheVirtualTim UV under both of the windshield and the roof is "pretty much nothing"UV is the opposite side of the visible spectrum from IR. The roof wont transmit much (if any) UV ... even without any coatings.
Plain ordinary glass blocks 100% of UVB and about 25% of UVA. That's not because of coatings ... it's just a property of glass (but it does need to be "glass" and not just something glass-like). But laminated glass does block about 99.9% of all UV radiation.
Also fun fact... green colored glass (such as those emerald green beer or wine bottles) also blocks all UV (blue colored glass does not).
I wold expect a UV meter to read pretty much nothing through that roof. IR is different... that's a much longer wavelength and IR can penetrate a lot of stuff. IR is just heat ... no danger of skin cancer (unlike UV). Gold reflective coatings are extremely good at reflecting IR (it's why the mirrors on NASA's James Webb space telescope are gold).
UV light meter UV ab about 290-370nm, about 11:38 am EST, May 12, 2021, NY.
Pointed UV probe directly at sun, 10.47 to 10.52 milliwatts (mW)/cm^2 during testing period (about 10 minutes), UV probe (oriented about vertical) in open driver's window resting on the lower sill, 8.29 mW/cm^2 (so, probably another cosine probe, this time with a UV transparent window)
-> UV probe oriented about vertical on dash - 5 micro W/cm^2 ("pretty much nothing")
-> UV probe placed about against roof about vertical - 4 micro W/cm^2 ("pretty much nothing")
IR to follow, probably need to measure in relative darkness of night with an IR source (or, some kind of bandpass filter for sunlight IR, another possible option)
