RobbertPatrison
- Mar 24, 2022
- Silicon Valley, California
- Ice White Mustang Mach-E
I used to drive a Chevy Bolt and Volt before my shiny new extended range AWD Mach-e. Chevy's electric cars displayed the propulsion and regenerative power flow conveniently on the dashboard. The Mach-e doesn't do that, so I configured car scanner pro to display and track a few nerdy parameters from the OBD2 bus. It matters: I am an electrical engineer
The MagSafe charging mount places the iPhone in a perfect position to the left of the main screen. The built-in lower wireless charging pad tends to heat up the phone, which is very bad for battery degradation. In the location next to the screen the air from the AC cools the phone perfectly:
Out of the dozens of OBD2 signals, I picked a few interesting ones that are relevant while driving. Here is what I observe in my extended range AWD:
The display while braking at low speed: Both front and rear motors have about the same braking torque. The combined regenerative braking power is 6kW at the time of this snapshot.
You can see the power flow of the past 2 minutes in the second row. I was driving downhill, so most of the power is negative. Below that is the speed in the same 2-minute period. The bottom row I picked the battery energy (with min and max markers) and temperature. I like SI-units.
- During normal acceleration, the front motor produces power only until 16mph(25km/h). At speeds above that, it switches off, unless you push the pedal to the metal. This is what you would expect in 4wd cars.
- If both the front and rear motors are engaged, the rear wheels do about 70% of the work.
- At speeds above 16mph/25kmh, the rear motor does all the work in normal driving: both acceleration and regenerative braking. There is no front re-generation at higher speeds. I presume that is also because the rear motor is more efficient.
- When braking at speeds below 15mph, both front and back motors regenerate energy to slow down the Mach-e. The braking torque is divided evenly front/back. That makes sense as it reduces the chance of a wheel slipping.
- When flooring the pedal for a 0-60 dash in unbridled mode, OBD2 reported a peak battery power draw of 429kW, which - at first - seems oddly more than spec. With the rated 355hp, the expected peak output power should be 265kW. But it might make makes sense because there are losses while converting electrical power into mechanical power. The 38% difference could indeed be the loss burnt in the inverters and the electric motors. Both motor and inverter will quite a bit less efficient when driven to the limit at maximum output. Though an energy loss of 48% might look bad, it is still much better than an Internal Combustion Engine that loses over 80% of the power.
- During the 0-60mph sprint, I see a maximum torque of 121Front+ 393Rear = 513nm torque. According to the spec it is 580nm but this could be a measurement error. I suspect that the torque is not measured but calculated from motor current and rpm.
- There is no difference in braking action between 1-pedal driving and normal mode. The computer blends in a lot of regenerative braking before any friction brakes are applied. In normal use, all braking is regenerative. Only with very aggressive braking do the friction brakes kick in. So you need to drive like a madman to heat up the brake pads.
- Unfortunately, the brake pressure signal is too coarse to track how the Mach-e blends friction and regenerative braking. I suspect that all braking is regenerative based on what I see.
- The heater power draw in 50F/10C weather is between 2kW and 4kW continuously. That seems about right: It would add about 10-20kWh of energy burn on a full charge. It would account for a range drop of about 30-60 miles. It will be worse with colder weather. If you want range, you must switch off the e-heat. Unfortunately, the Mach-e has a habit of sneakily switching on e-heat. The GM cars had an 'ECO mode' that avoided the hidden climate-energy burn.
- The AirConditioner power is remarkably low. I measure about 0.7kW in 27C/80F sunny weather. That would 'cost' ~10 miles of range. This is less than what I saw in my Volt and Bolt.
- The seat heater draws about 0.06kW, which is negligible. The heated steering wheel is too small to measure.
- Note that there is no heater power reported in the OBD2 signal list. So I derived that from measuring the battery power difference when switching things on or off. There is a signal that shows the AS compressor current. I see current values of approx 4A when running, which is off because at 370V that would suggest a lot higher power draw.
- With the radio on, the power-on battery draw is only 450Watts. That is slightly better than what I saw in the Volt and Bolt.
- The Headlights add ~70Watts: it is insignificant. LEDs are very efficient. The old Halogens used to be 50 Watt each.
