billc58
- Bill
- Jun 16, 2022
- Victoria, BC, Canada
- 2022 Mach-E GT PE, 2019 F350 Platinum
I want to compile the tips and tricks spread throughout the forums for faking Pet Mode.
Before the tread fills up with complaints, yes Ford, you should put out Pet Mode like Tesla and Rivian.
- Leave the ignition on so the A/C works.
- Disable the auto shutdown to avoid everything turning off in 30 minutes. This setting is not sticky, so must be done every time.
Disable the internal sensors to avoid the pet setting off the alarms. This setting is not sticky, so must be done every time.(Not needed if car is left on).- Play some music, maybe the Eagles. This is optional, but might prove to others that the A/C is on.
- Put up a sign letting others know that the car is in Pet Mode.
- Leave and lock the doors.
