ThomF
- Thom
- Feb 17, 2021
- Whitefish Bay
- Ford Mustang Mach-e
- Engineer-historian
I picked up my Mustang on Monday. It was originally ordered in April and manufactured in late July, but then held up for apparent chip shortage issues. The dealer provided me with a modest discount because of the delay (I actually had a different one on order that arrived earlier and I allowed it to be sold to someone else--decided that I preferred the silver exterior to white). The dealer also applied the Ford X-plan.
It's a premium, 4WD, ER with black interior.
The photo below shows its first plug-in at a public charging station. Interestingly, this particular station (outside a Kohl department store) doesn't show up on the network, nor on most map sites. It does show up, however, on the PlugShare app. The sign in front of the two available stations says something about getting a card from Kohls at their service desk--something the service folks knew nothing about. I was able to connect through the ChargePoint app. Since this charge point is the nearest to my home, I figured it would be good to get to know it!
I'm still using 120volts at home, which has been working reasonably well. I'm awaiting an electrician to set up a 240volt outlet, which should occur the week after Christmas.
The set-up has gone reasonably well, although I'm having a few minor issues:
Now, I just need to keep the salt off of it. It would have been nice if it had arrived before winter set in!
Thom
- I haven't been able to get it to pair with my garage door opener. My opener is pretty old (a Chamberlain) and the normal pairing sequence doesn't seem to work. As I recall, i had an issue with my wife's Edge a couple of years ago, but eventually got it to work.
- I haven't been able to get Android Auto to work wirelessly, although it is working fine via USB cable.
- When I connected my Android phone to the vehicle (back at the dealer) it connected through the FordPass app. It never went through the normal handshake via Bluetooth. When I remove the phone and reconnect, it simply shows up. I'm thinking that this might be the reason that Android Auto isn't working via bluetooth. Any thoughts would be helpful.
- Available mileage is showing pretty low. I'm limiting my charge to 90 percent and it is showing 177 miles (on an ER battery). That's about 200 miles on a 100 percent charge. I'm assuming that is pretty normal for the winter months (it's been hovering around 32F as of late). If there is a 30 percent winter penalty, that would get me to 285 miles range.
Thom
