hybrid2bev
- Dec 4, 2019
- USA
- 2021 Job 1 Premium4X - EAP Member
First the good news. From 12% to 80% took about 45 minutes so about right on target. I was able to start my charging session using Apply Pay on two different units, no charging faults (did not stop after paying until I stopped it). I don't have a membership so it charges $0.43 per kW instead of the member rate at $0.31 per kW.
I activated my Plug & Charge free 250kWH offer in Ford Pass earlier in the day. I drove my car around today until I reached 9% state of charge. Had been driving hard for about 90 minutes before plugging in at an EA station.
I had the car turned off. It was 26 degrees F outside.
When I first plugged in the charger said connecting to vehicle, then it asked me to pay for the charging. I disconnected and moved to another charger, same thing. Decided to just pay for the charging on the 150 kW charger using Apple Pay which worked just fine. Plugged in at 9% and got 55 to 57 kW speed. I let it go to about 12% charge and disconnected. Thinking maybe the station could not put out enough power.
Moved to the 350 charger that I first started at but used the second cord. Plugged in... Plug and Charge failed so I just paid for charging using Apple Pay... started up at 57 kW at 12%. I will add that during the process the kW speed jumped around by a few kW it didn't seem to hold a steady rate. But it never stopped charging.
Below is the rest of the session data. Sorry for the gaps (had people come up at different times and want to talk about the car). The speed seemed to jump around a bit, this may have been the charger?
Start of the second session:
Peak Speed of 125 kW:
80% cliff: 12 kW. I let it go here at this speed for a couple minutes but it did not move off of 80%.
End receipt: $0.43 per kWh as guest
