Poll: Have you gotten OTA 4.1.2 (the UI refresh)?
4.1.2 - Didja Get It Yet?
  • Total voters
    1,160
Bt3
Eastern Iowa
2014 Mazda 3
4.1.2 just showed up a little bit ago. Much zippier menus. I'm CR1 2022 non EA in the US
Logal727
C
Finally got 4.1.2 today. Really cool update, the icons are shameful lol.
The only issue I'm noticing and it may go back to normal after a few key cycles, but I have got connectivity all working OK but there is no icon in the top right corner for it and the dropdown menu for Connectivity in the settings menu does not work. It's just blank. This usually happens if the TCU is stuck but, connectivity is working this time just fine. Weird!
So my connectivity symbol came back today and then I shut the car off and came back a few hours later and started and it's gone again. Everything is still working fine connectivity-wise, but the connected vehicle features dropdown isn't populating. Seems like a bug on the server side or something with the update.
voxel
Nelson
Altamonte Springs, FL
22 Mach-E 4X, 23 GC Limited
I also got scheduled for 3.6.1 today--first update since early December.
Same.
My first update since Oct. so maybe I will get this 4.x update soon.
I usually keep my Mach-E around 50-60% at home (spoiled by free work charging) and yesterday it was near 80% charge for the first time in weeks.
hawkeye3point1
NH
What do you mean you started it? How did you manually update?
3.6.1 and 3.6.2 are inhibit updates, meaning the car can not be operated. Inhibits are normally installed at your scheduled time or by using the Sync Update Now command. Update Now does not do anything for non-inhibit OTAs, FYI.
Phil-Springs
Phil
Colorado Springs
Mach E CA RT1 AWD Extended DMG 2022
just got notified of 3.6.1 today. July 22 build and no updates since end of Oct (the dc faster charging update). FORD.com inspect trick works to know if you have been "pushed" the update. Looks like the roll out is just slow unless you've get a specific install error.
Dustus
Dustin
Boise Idaho
2022 Mach E GT
Just got 4.1.2 this morning. 4.1.1 was 2 days ago. Same as others. 4.1.2 had no messages, just appeared. Makes me think that 4.1.1 was the real update and 4.1.2 was the a flip of the switch once it thought it was ready to go.
Mirak
Mirak
Kansas
I think 4.1.2 is a much bigger download. Which might be way it takes 24-48hrs for most people. I got 4.1.1 yesterday and 4.1.2 is in progress now. It’ll probably finish tonight in my garage.
What if I got 4.1.2 but nor OTA? There’s no choice for that.
Took the car in for the 20K service and 22B28 today. I also had a list of quirks I gave them (the usual stuff..CarPlay connect, etc.) and told the if there’s any updates that could help these issues, I’d like them applied. I also mentioned that it would be nice if the interface was the same as my new Lightning. I picked up this afternoon and there it is, persistent camera button and all.
Maybe it’s technically not 4.1.2, but I’m sure happy!
Mirak
Mirak
Kansas
I received 4.1.2 today. A few interesting things so far:
  1. No alert that I actually received the update. I just have the new interface.
  2. Screen was stuck in bright or day mode. I had to reboot Sync to get back to dark mode.
  3. On my screen, I don’t hate the top ribbon clip art items quite as much as I thought I would. I just strongly dislike how bland and non-intuitive they are.
  4. I’m still very annoyed they didn’t put the rear hatch on the top ribbon.
  5. Ford appears to have shrunk the size of the bottom ribbon HVAC controls? Hmmm. They seem too small now.
  6. Such a small annoyance, but wish CarPlay would ditch the rounded corners.
Regularmache
Stephen
US
Purchasing
First Edition owner, and now in a 6/22 GT PE and as I look back at the OTA updates, or Stuckdates I'm some cases, I see a steady improvement and this new UI is so much more intuitive. The overall trend since early 21 with Software is going in the right direction.
bfleischer
2018 Chevrolet Bolt EV, 2015 Honda CRV
Director - Information Systems
Still on 4.1.1 since 1/13…almost two weeks and still no new UI… anyone else experiencing this?
I got Wi-Fi on, and scheduled updates 7 days a week at midnight. 1st world problem, I know… but I want the new UI whaaaa….
CherryBomb
Ft Collins, Colorado
2022 Rapid Red Mach-e GT
Make sure it is actively charging for at least two hours immediately preceding the scheduled update time. Modify your charge or update schedule so this can occur.
My car was failing to update to 3.6.1 so I plugged it in and charged for a couple of hours to about 93%. The car is in my garage connected to a strong wi-fi signal . Rather than waiting for the next scheduled update at 1:00AM tomorrow, I left the car plugged in and restarted the update manually. This worked and 3.6.1 installed successfully. Now waiting for 3.6.2.
