Potential water in battery tray
mercerless
Brett
Ponte Vedra, FL
2021 Ford Mach E Premium AWD ER
2021 Mach-E AWD Extended Battery model.
In August we got a 'Powertrain malfunction' alert on the dash. The car still drove fine that day but we reached out to the dealer that day to bring it in.
It took about a week but they determined the rear drive motor needed to be replaced which would have taken about 2 months to get a new motor from Ford. They also found water in the battery pack when it was lifted to look. They kept the car for about a month and worked it down to the oil pump on the motor that needed to be replaced. As for the problem with the battery pack I was told that it wasn't water in the pack itself, but it was found in the tray that the pack sits inside. The diagnosis from the dealer is if we feel there is still water in the tray, hear it sloshing around to just park it on a curb to let it drain out.
Since that time we still hear sloshing, I've also read posts where it's possible to hear this from the coolants for the battery pack. https://www.macheforum.com/site/threads/sloshing-sound.20755/
First...how bogus is it to get told by the dealer to 'park it on a curb to drain'? Is this an actual remedy? Has anyone else been told this? Second, if there is the possibility of water getting in the tray of the battery pack, how concerned should I be long term? Has anyone else had this issue?
I'll be honest here, my wife really wants to trade in the car since we were told that by the dealer. I am ok with keeping it I guess but I understand her concerns. Would replacing the car be on your mind if this was yours and the warranty expired in less than a month?
And no, we don't live anywhere near where the hurricanes hit recently and the car has not been in any deep waters.
Ford Motor Company
Official Ford Account
Hey there. Can you please send over a message with your VIN and the name/location of the Ford dealer you have been working with? I would like to take a closer look into this.
That sounds very bogus to me. The battery tray/enclosure is supposed to be airtight, so zero water should be able to get in or out. There might be a tiny amount of water on top of the battery because of the A/C drain dripping on it.
If there is water inside the battery tray, it can touch high voltage and corrode electrical components. Which needs to be fixed ASAP. I hope they didn’t do anything stupid like drill a drain hole in the bottom of the pack.
Sloshing sound or bubble sounds might come from the coolant pumps pushing coolant. But that should stop as soon as you turn the car off.
CARSMASH
roumaissa
Algeria
LAND ROVER
The idea of parking the car on a curb to allow the water to drain may seem a little simplistic, but it is a solution that can help if the water is actually trapped in the pan. This can work if the water is not blocked and can escape naturally.
