1969Mach1Mike
- Mike
- Jul 3, 2021
- CO
- 69mach1, 11 R56S MINI, LR LR4, Mach-E IBSM.
- Minister Of Awesomeness
Many buttons will show normal and (ENABLED/ON) , but actually are NOT enabled. You may see the message along the lines of "Connectivity Needs to be Enabled to Access this feature'. You connectivity will show ON and ENABLED. You can move the slider back and forth but the setting will actually be off and remain this way despite the GUI indication (Interface Visual).
Reset the Center Screen(Hold Volume Down+Next TRACK).
I do this after any update regardless. However it is imperative with the particular OTA. The RESET will re-activate everything. I suggest you go through all of the settings you use and toggle OFF/ON to achieve your previously desired configuration options.
BUG FOUND:
I'm having issues with (HD Radio) Staying enabled. It turns off every-time I switch stations and has to be manually enabled constantly following this OTA.
Full screen Android Auto! Yay!
BUG FOUND:
