Question on electronic frunk release
question on the electronic Frunk release: did ford add a key combination on the keypad to open the frunk? I know it was mentioned early on, but I don't think they actually implemented it that way. It would be so much more useful than having to dig out my phone, open the app, and hit the frunk button. Also, does the frunk button in the app require PaaK to be setup?
Ford said early on the frunk will be able to be opened with the 7-8 button on the keypad. I’ve asked in other threads for GT owners to try holding in that button to see if it opens the frunk, but haven’t had any takers.
DevSecOps
Todd
CISO
Which specifically are those. I'll try for you. Edit: i thought you were referring to the fob then it dawned on me ?
And yes I believe you have to have PaaK from the phone
With the car unlocked, try holding in the 7-8 button on the door keypad. Does it pop the frunk? If not, try entering your unlock code and then holding. 7-8. Anything?
DevSecOps
Todd
CISO
Excellent, thank you! Does it do anything if you don’t enter your code first?
I'll try in a bit and report back. I'm going on a mini road trip since @timbop stressed me out ?
As a side note if anyone ever wants me to try something just DM me. Always willing to help
Confirmed it worked. I did my code then held 7-8
Great! Now we just need to know if it will work just by having a fob/paak in your pocket, pressing the opener button on the door to unlock it, and then the 7-8 button. That is, as @generaltso suggest just hold the 7-8 with the car unlocked and the key in proximity - which would be awesome if it worked!
DevSecOps
Todd
CISO
Ok so I tried unlocking, from locked and holding the 7-8 key and with already unlocked and holding and that's a no go... You must enter your code first.
Thatā€˜s a bummer, but better than nothing. Thanks for trying it!
I guess the assumption is you're coming back to your car from the store, it's already locked, you unlock it, then pop the frunk so that you can put your groceries in there. They probably didn't think of a case where you may be at a car show and everything's already unlocked and want to show off the frunk (or perhaps dismissed it as irrelevant).
I guess, but I’d be willing to bet that the door keypad is not the method that is used most often to unlock the car.
I'm thinking you're right, which makes it all the more strange that you can't hold the 7-8 button to pop the frunk if the door is already unlocked (say, if it's unlocked due to PaaK proximity).
