Rear view camera delay setting doesn't work and switches itself off.
cdr_taggart
Ethan
San Jose, CA
Mach-E First Edition
Does anybody's rear view camera delay setting actually work?
Update: After several attempts at getting the setting to stick, it's working. No idea what I did differently this last time.
Mine seems fine. When I pull into my garage, I'll momentarily put it in R to trigger the backup camera, then switch back to D and watch it as I pull in to see the clearance from the door.
JellyBelly
Kris
MME RR FE
Yes works for me so far - the delay is for when you are done reversing and start driving forward, it stays on just a bit.
Smithcar
Kevin
Massachusetts
Mustang Mach E
I have this issue. The delay selection does not stay on and turns off. It works it turned on right before reversing but the will be “off” the next time. Any trick to keeping it on.
