Regenerative braking
Dkuhnke
Cobourg, Ontario
ordered Mach e FE, but ETA is anyone's guess
retired engineer
Does anyone know how the regen braking works? Are there paddles on the steering column or built into the brake pedal?
eager2own
Southlake, TX
Although there are user-controlled settings for how strong the regen braking is, the actual application is transparent to the user. You apply brakes (or just release the ā€œgasā€, depending on your settings) and software drives whether regen braking and/or traditional braking kicks in.
There isnā€™t a separate regen braking input (like paddles) needed.
SJ_Okay
Scott
UK
ā€˜23 GTPE
With the MME, the level of regen will be dependent the 3 drive modes. Whisper will have the lowest regen and be more of a cruisey feel, where as Unbridled will have the strongest regen. Itā€™s built into the accelerator pedal. As soon as you lift your foot off it, itā€™s starts to regenerate. Additionally, the brake pedal in the MME will also provide regeneration.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
When driving in 1-pedal mode you don't even touch the brake pedal. The top X% of the accelerator becomes "brake" (like top 5% or maybe 1/2" of travel). When you lift your foot off the accelerator the car will automatically start regening (you can modulate this using the accelerator just like you would for acceleration). Its easier to simply drive and do than it is to explain in text LOL. Completely lifting your foot off the accelerator will bring the vehicle to a complete stop (Ford has stated that in this instance the car will automatically use its friction brakes below about 3mph and to hold the car in place).
My guess is that Ford will probably also offer the blended brake (since they are already doing this on their hybrids and the Focus Electric).
The blended brake seamlessly blends regen in with the friction brakes when you press the brake pedal. This means that regardless of how you drive you'll probably be taking advantage of regen...
jeffdawgfan
Jeff
Georgia, USA
You will rarely use your brakes once you get used to the one pedal driving. I love it personally. Our Chevy Bolt had excellent regen braking. Never had to hit the brakes unless someone pulled out in front of you unexpectedly. Our 2019 Leaf Plus...well, I would prefer it to regen a little more aggressively but Nissan did not feel that way......
Dkuhnke
Dkuhnke
Cobourg, Ontario
retired engineer
Thank, folks. I'll just have to wait for delivery in the Fall.
Mach Dad
Jeffrey
Oxford, MI
2010 Ford Fusion Hybrid, 2014 Ford Explorer
Consultant
I'm not sure how much detail you were looking for 'how does regen braking work', but I thought this video below was excellent. Even if this isnt what you were asking I'm sure others might be interested.
Nak
Camas, Washington
Tesla Model Y Performance, Tesla Model 3, 1992 K1500 Blazer
Has this been verified, or just assumed? There's been a lot of misinformation provided by trolls on this subject here. I'm not saying you're wrong, I just haven't seen it verified anywhere.
Billyk24
William
PA
The above states how my Ford Escape Hybrid-Ford Cmax Energi and Toyota RAV4 Hybrid worked: lift your foot off the gas pedal and it regenerates, press/tap the brake pedal and regenerative braking occurs. Off course these vehicles were of the Patent Power Split design which is got to be similar to what the Mach E will do.
SJ_Okay
Scott
UK
ā€˜23 GTPE
Ron Heiser, Chief Engineer on the Mach E said this in an interview... hopefully heā€™s not trolling us.
  • Like
Reactions: Nak
Ken7
Ken
Tesla Model S, Lexus ES300h
I would hope, as Tesla does, the level of regen is not tied to a particular drive mode but is an entirely independent choice. Linking regen to a drive mode was the setup that existed in my wifeā€™s Honda Clarity PHEV. To get maximum regen you had to be in Sport mode. We wanted max regen but there were aspects of Sport mode we didnā€™t like (lower range among other things), so we never used it. Unfortunately the level of regen in the normal mode was so weak, you actually couldnā€™t feel it and thus one pedal driving wasnā€™t even a distant thought. :(
The much better approach is to allow the regen level to be an entirely independent selection. Iā€™m a bit concerned about this and if it is tied to a drive mode, how weak is regen in the normal mode?
SJ_Okay
Scott
UK
ā€˜23 GTPE
From what I remember, he implied that youā€™re able to set one pedal driving yourself and tune the level of regen and additionally that the drive modes have their own level of regen settings... Whisper gives a sort of coasting feel to the drive and unbridled was the opposite with heavy regen and more aggressive tip in on acceleration... Iā€™ll try find it now... itā€™s quite an old interview, so might involve some scrolling. But I do definitely remember him saying you get regen via the brake peddle as well... which is great.
Ken7
Ken
SJ_Okay
Scott
UK
ā€˜23 GTPE
Ah, thanks! It does seem like the drive modes and tailored regen would be independent if I'm understanding him correctly. He does say the drive modes have their own level of regen, but it sounds like you're not tied to that for adjustment of regen if you so choose. Fingers crossed! :)
Yeah, fingers crossed indeed! Iā€™m also really hoping for some detailed drive mode customisation! If by ā€˜weā€™ he means the customer and not Ford, are able to tune the regen, then Iā€™m really hoping for more car tuning functionality for us to play with. I feel like Darren Palmer was hinting/teasing that itā€™s possible in this interview below... although he did say the car had 800bhp, so who knows, lol! But Iā€™m reeeeally hoping theyā€™ve got some neat tuning functionality up their sleeve for us. Check it out from 11min -
