Road trip from Phoenix east valley to Joshua Tree
JMSMachE
NorthWest Ohio
‘21 Porsche Taycan,’21 Audi Etron, Town&Country
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
Machine Control Specialist
Charge log:
Miles Traveled
WaypointStation
Planned Arrive %
Planned Depart %
Actual Arrive %
Actual Depart %
0​
HomeL2
100​
100​
55​
BuckeyeEA Walmart
71​
80​
80​
82​
99​
QuartzsiteEA Love's
16​
78​
35​
83​
87​
Chiriaco SummitCP Chiriaco Restaurant
23​
33​
39​
45​
driving from hotel in La Quinta to/from/around Palm Springs(unplanned)(unplanned)
179​
79675 Hwy 111, La QuintaL2 Residence Inn
18​
100​
17​
100​
driving through Joshua Tree N.P.
133​
32​
61​
45​
80​
86​
QuartzsiteEA Love's
10​
80​
41​
80​
100​
BuckeyeEA Walmart
15​
47​
29​
39​
56​
HomeL2
15​
15​
Would you skip a couple of charge stops if you were to take this trip again?
AllenXS
Allen
Richmond, BC, Canada
Premium Blue ER AWD
For many people, yes. But I am farsighted. My distance vision is great. I'm just getting "old" (presbyopia) and having eyestrain with the close up stuff.
I suppose progressives for driving might do the trick if I could get used to them.
Takes a little while to get used to them. The sunglasses with prescriptive are great. I use them a lot when outside for reading stuff. No headaches!
dbsb3233
TimCO
Colorado, USA
I was also having quite a bit of shoulder and neck pain. I can't seem to get seat and steering wheel in a comfortable position while still being able to see instrument cluster. I've been experimenting a lot here but just can't seem to find a good arrangement. I wish I could move the IC down an inch or two, and I wish the steering wheel could be extended out towards me further than its current limit. I ended up putting my hands palms down, at 5 and 7. This was pretty awkward for me, but it gave me some relief from the strains.
I had some of those same struggles at first too. Neck we getting a little sore. But then I changed the seat to sit more upright and that seemed to fix that one.
Finding a comfortable hand position is still of a bit of a struggle for me. I like to rest my arms in my lap and grab the wheel at the bottom when cruising. My Escape steering wheel is open at the very bottom (with spokes at 5 and 7 o'clock). That was perfect for holding it at the bottom with my right hand. But the MME has that goofy split spoke at 6 o'clock. It's just totally in the way for holding the wheel at the bottom. But, the 5 and 7 o'clock positions are open for a good grip. What I end up doing a lot is turning on ACC, pulling my feet back to the seat with knees up, and grabbing the wheel underhand (palms up) at 5 and 7. That's pretty comfortable, with arms resting on my legs.
I like to sit high for best visibility (and least direct sun), so I have the seat high and the wheel low. But I can't put it too low or I block too much of the IC screen. Wish the wheel were a little bigger around.
dbsb3233
TimCO
Colorado, USA
I like your tracking log. I keep debating what data I want to collect and I wish there was a more automated way of doing that.
BTW, great photos too. I sometimes feel a little awkward when we have stopped at some scenic place. Everyone is taking photos of the scenery and I'm snapping photos of the car. LOL
I used the charge logs for mine after I returned home. I knew I wouldn't remember to write things down (or take pictures) every time. But between EA, CP, and FP, I was able to piece it all together (each one had some holes, but the others filled them in).
dbsb3233
TimCO
Colorado, USA
Charge log:
Miles Traveled
WaypointStation
Planned Arrive %
Planned Depart %
Actual Arrive %
Actual Depart %
0​
HomeL2
100​
100​
55​
BuckeyeEA Walmart
71​
80​
80​
82​
99​
QuartzsiteEA Love's
16​
78​
35​
83​
87​
23​
33​
39​
45​
179​
18​
100​
17​
100​
133​
32​
61​
45​
80​
86​
QuartzsiteEA Love's
10​
80​
41​
80​
100​
BuckeyeEA Walmart
15​
47​
29​
39​
56​
HomeL2
15​
15​
Did you set a trip meter for the whole trip? If so, what did you show for miles/kWh for the whole trip?
I added up the %'s for your departures at the start of each leg and arrivals at the end, and got 308%. For the ER battery (68 kWh), that's 209 kWh used. Your miles add up to 795. That works out to 3.8 miles/kWh. Even in the RWD in good weather, that sounds surprisingly good for mostly interstate speeds.
MY21 J1 Premium RWD SR
Here is the meter at the end of the trip. I don't trust it for its efficiency model, but the number of miles travelled should be right. So my numbers from the chart may be a bit off, as this says 709 miles.
I was driving at the speed limit most of the way, mostly 70 or 75 mph. Within Phoenix metro (about two hours of driving on this trip) I have to drive faster than the limit or I'd be a road hazard. Within the metro area the limit is 65 so I was going about 70.
Ford Mustang Mach-E Road trip from Phoenix east valley to Joshua Tree PXL_20210508_043451723
No. The only ones I'd consider skipping were Chiriaco on the way into La Quinta and Buckeye on the way home. Either way I'd have arrived with just a handful of miles left. But if I'd skipped them it would have messed up our spontaneous plans to go to other sightseeing stops or various restaurants for dinner (we stopped a few places before finding something agreeable and not crowded).
BMT1071
Glendale, AZ
Buckeye on the way out seems like it could go. Certainly wouldn't be a stop for me as we live on opposite sides of town. ?
dbsb3233
TimCO
Colorado, USA
That fits better. 709 miles / 209 kWh = 3.4 MPK. That's more in line with what I'd expect in the RWD in good weather (although 3.1 seems even more likely). Probably somewhere in that range, anyway.
I did find mine worked out exactly the same (2.6) as what the trip meter showed. I feel pretty good about it for that, over many miles anyway. Short distance is prone to skewing though.
It's the "How's My Driving" stats that I find to be less accurate than a dartboard. Totally useless, so I just ignore it.
Yeah we're probably 45+ miles apart. You're absolutely right though... I forgot until now that the only reason I stopped in Buckeye on the way out was to see if DCFC works. It was the first time I charged outside my own garage. Buckeye was my safe turnaround point if nothing was working.
For you efficiency wonks (hey @dbsb3233!!):
A shorter trip today... Picked up Mom, took her to Boyce Thompson Arboretum and then dropped her back off. Oh and I bought a small Desert Willow tree and planted that, too. ? :)
Charged to 100% before hand and when I returned home the vehicle is at 51% remaining.
According to Google Maps, the routes I chose total up to nearly 126 miles. 43.5 are suburban traffic, 82.3 are highway. That means approximately 35% city, 65% highway. AC was on all the time (mid-90's here, and mid-80's at the arboretum which at about 1,200' higher elevation).
Doing some math, that is 125.8 miles used for 49% of 68 kWh, or 3.8 miles per kilowatt hour. Not bad!
Ford Mustang Mach-E Road trip from Phoenix east valley to Joshua Tree PXL_20210509_173501047.MP
Ford Mustang Mach-E Road trip from Phoenix east valley to Joshua Tree PXL_20210509_182738900
BMT1071
Glendale, AZ
I'm a couple miles north of the Cards stadium.
