Rusty is rusty…
pickupMache
canada
2023 mach e select awd
Ford Mustang Mach-E Rusty is rusty… 0205BC5A-08E4-4406-BBB7-00224BCB466B
I got MME 2023 two months ago
they are the door strikers.
yesterday I found them rusty except one.
what should I do?
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Looks like a small amount of surface rust. I think just humidity would do that. I wouldn’t worry about it. But if it really bothers you the part should be pretty cheap and easy to replace.
zvez
chris
ga
Show it to dealership on next visit. They will likely treat it.
AliRafiee
Ali
Seattle WA
Software Eng.
thanks. but I think It is supposed to be covered by warranty.
I have a feeling they will say it’s normal. Either way I wouldn’t want to not have a car for a day and drive to the dealer for $20 part and 15 minutes of work. But if you’re already there for something else and they already have the part in stock, it’s worth a try.
Or dab a little oxide conversion solution on it to turn it black. ?‍♂?
SWO
MD, USA
You could spend hours fighting with the dealer over it, clean it up with penetrant and a soft brush, or do nothing. Those strikers will be working fine when the car goes off to the crusher whether that's in 10 or 30 years.
More likely to have a door alignment issue if you make the dealer swap them, in my opinion.
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
I showed my dealer the bubbling on the door from that letter. Someone said that’s out there but because I never got my letter they won’t put it in the body shop yet.
Totally different things. And if your vehicle was built before June 10, 2023, whoever you talked with at the dealership is incompetent. No letter is needed, they look it up in their systems.
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
Yeah, I think I looked that up before mine built before 10 June, I looked again, 5/23/23
nvabill
Virginia Beach, Va.
F-150, '22 California Route 1
what should I do?
Totally unacceptable, take it to the dealer and demand it be fixed under warranty and furthermore demand they furnish you with a free loaner of equivalent status to your Mach E!
