Golfer
Eric
Vegas
Mustang GT, i3
Saw this over on the sister site F150gen14.com -
https://www.f150gen14.com/forum/threads/fordpass-scriptable-widget-ios-ipad-macos.7444/
What a super cool idea. I haven't tried it yet but this should work just as well for the Mach-E.
By @tonesto7
I figured I would share something I've been working on.
Many months ago I found a fordpass widget while searching for some Ford pass API stuff.
At the time I didn't even know what Scriptable was...
I work with Javascript every day so this was an amazing find for me and it allowed me to interface with my truck without having to use the FP app.
So I completely refactored the entire script into an alternative control to FordPass.
Take a look at the readme file and you will see what it does...
It stills needs more work to be very easy to show the right icons and names for the entire ford lineup but it will get there.
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) 1639255355685-
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Thanks again to dschablowsky for all his work on the original script...
cjrodriguez31
Corey
Rhode Island
2021 Mach E GT - Towed 4 times/9 months
This looks awesome and Im 100% trying this when i get home from work.
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
By @tonesto7
Coolness! At last an 'app' that lets me know if the damn thing is locked...
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
@tonesto7 Is a member on this forum as well :)
COACH CHRIS
C
NJ
Mustang Mach-E AWD Select
This is amazing. Will be trying this out this afternoon.
COACH CHRIS
C
NJ
Well, tried it out and got here:
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) C6FD66E6-0228-43F0-B39F-F4E3921B7D3C
Thing is, I moved a bit too quick on the tap and selected my car as the F-150, which it is not. :rolleyes: Is it easy enough to change? Unfamiliar w/ code of any kind and don’t want to break this. (Though I suppose I could just re-paste and start over.)
txaggies07
Aaron
Houston, TX
2021 MachE FE Rapid Red
I selected MachE and still got this same error
migna
Francesco
Italy
Mach-e rwd extended
Really cool, I will try for sure!
Yup, it doesn't like the Distance To Empty variable for the MME. Just take out that line. Then it will error on line 1431 too, so take that one out as well. I did that and now it works for me. There's obviously no data for Fuel Level or Oil Life, but everything else seems to work. I couldn't see all of the tire pressures on my iPhone 12 Mini with the medium sized widget, so I switched it to large.
You can change the vehicle type in the Scriptable app. Just click on the widget and select Widget Settings. I think the only thing the vehicle type is used for is the picture in the upper left. Of course, it's not the right color for me, but I'll survive.
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) 1639426075202
migna
Francesco
Italy
Mach-e rwd extended
One curiosity. Why you have included a "fuel" label instead of "battery"?
I take this app would work with other cars as well, I was wondering if there is a possibility to have customised field(s) based on the car
Because the author created it for an F-150. The entire script is custom, so it can certainly be customized for the car if you know how to do it.
jjwolf
Justin
Vancouver, WA
MME Premium 4X, M3, Yukon
quick JavaScript hacking course... if something throws an exception, put it in a try/catch block. both distanceToEmpty and fuelLevel needed this for me..
so this:
carData.distanceToEmpty = yadayada;
becomes this:
try {
catch {
carData.distanceToEmpty = 0;
Do this for fuelLevel as well.
so this:
becomes this:
try {
catch {
Thanks. I'm not a programmer, so I just took the scorched earth approach and removed those lines.
markboris
Sonora, CA
A few months ago I created 10 Siri shortcuts and two of them were DTE (Range) and battery level. I'm sure we can get those to work for this widget.
Edit: Just saw Justin posted the info for those
hetgeleteken
Martijn
Utrecht, NL
VW Golf Estate, Ford Mustang Mach-E AWD ER Lucid Red Tech+ reserved
Looks awesome, although I get an error when running the script.
