Selectable AWD? Has this been asked?
pb3
Phil
California Central Coast
Lincoln MKX, Toyota 4Runner, MME Premium AWD ER (order accepted!)
It occurred to me -- what's preventing a feature to allow the driver to switch from AWD to RWD-only when the former isn't needed?
This would potentially save a lot of energy even if the front wheels can't "freewheel" per se.
OTA feature upgrade?
EVer
San Diego, CA
Ford F-150 SuperCrew Cab, Tesla Model 3P
I don’t believe the front motors can free spin
  • Like
Reactions: pb3
pb3
pb3
Phil
I wondered about that. But what if they got enough juice to match the speed of the rears without actually adding any "torque"? Wouldn't that save energy?
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2021 MME
Might be one of the drawbacks from having the motor in-line, but I like the idea. I'll assume that Ford will make this as efficient as possible when my inputs don't require the torque or for traction.
  • Like
Reactions: pb3
dbsb3233
TimCO
Colorado, USA
No, because whatever torque the front motor adds means less the rear motor has to add, and vice versa. It likely adds up to about the same kWh usage either way. Maybe a tiny difference but negligible. And Ford likely tunes that to balance it for the best efficiency anyway.
If anything, you want the smaller front motor to do the heavy lifting when cruising, reducing the work by the bigger rear motor.
dbsb3233
TimCO
Colorado, USA
It's geared the opposite way though (front at 10.0:1, rear at 9.05:1). Not sure it really matters when always engaged though. What probably matters more is the efficiency of the motors at different RPM points. They could have different "sweet spots" for the RPM ranges they're most efficient at.
I really don't know enough about it though. More just kinda speculating.
Yes, I agree with your earlier assessment that it might have made sense for maximizing highway range to have a lower gear in front. The gearing on those two motors was probably optimized using the simulators.
  • Like
Reactions: pb3
The front motor has a higher rpm limit so it can have a steeper gear compared to the rear motor. Benefits are more torque multiplication for acceleration and RPM increase for regeneration. It looks like the front motor is responsible for the majority of the regeneration on AWD vehicles. You can get a clue to this by looking at all the cooling plumbing shown in the owner's manual and from the factory photos of the chassis assembly.
The 10 to 1 ratio up front means the motor turns 10 times for one wheel rotation. That is opposite of what most people mean when they say "highway gear"
  • Like
Reactions: pb3
Silly question: isn’t there some kind of clutch-like mechanism in the propulsion units (whatever those things from borg-Warner) are called) that would essentially disconnect them from the drive shafts on command?
  • Like
Reactions: pb3
Nope.
