Set to charge to 90% but charging all the way to 100%
macgyver60
michael
New York
Mach E Premium AWD Ext Range
After reading a few things about proper charging I set the charge limit on my MME to 90% when charging at home. Since we dont have an electric plan that has lower rates for nighttime use I set charging to be allowed at any time. Despite limiting the charging to 90% it has charged to 100% each time I plug it in overnight. I am using a ChargePoint charger in my garage. Any ideas why its not stopping at 90%?
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
This is becoming a very common question around here. 1st issue is always, are you setting the 90% limit in your app? Or on the car’s big screen? The app is garbage. Use the screen. Secondly, have you saved the location for your place of charge? Thirdly? Do you have “charge whenever plugged in” selected within the app, or do you have a schedule set on the big screen.
Jimmy2
Jimmy
Wilmington NC
21 MME Premium 4EX; 23 MME GTPE Vapor Blue Met
Let us know if this gets sorted. Works fine on mine.
macgyver60
macgyver60
michael
New York
I had programmed everything in the app and in the car. The only thing i had wrong was that i had it set to charge when plugged in. Ive changed that. Ill let you know what happens next time i charge. Thanks for all the feedback. Hopefully that fixes the issue
PCPilot
Frisco, TX
2021 Mustang Mach E, FE
The charge settings are an unintuitive mess, like pretty much everything else on the FordPass app. On the Tesla app, you have one battery level meter with a slider bar to set the charge limit and boom, you're done.
timbop
It's almost like Tesla has had years to refine the UI.
mamejunkie
Orange County, CA
Premium Mach-E '21, Premium Mach-E '22
But shouldn't Ford just copy what works? New players shouldn't have to start at zero. The software on the Ford def has a long way to go. For users who want to say, charge whenever I have it plugged in but keep the upper limit to 90%...it should be a easy and common use-case.
Exactly.
djett
CT
Mach E Premium AWD
Just wanted to thank all for having answers to my issues as I hit them.... Came out to the garage to my car at 90% when I thought I had it at max of 80%. Made changes recommended here, guessing that will do the trick.
macgyver60
macgyver60
michael
New York
That worked. Charged to 90% last night. Thanks for the suggestions
Thought I should update this. After following the suggestions the app did say it had completed charging to 90% the next day but when I got in the car it was charged all the way to 100%. Since Ford has built in a 20% buffer on the battery Im starting to think it doesn’t really matter.
Timelessblur
Tyler
Austin
Mach E AWD Premium Extend Range RR
Software Developer
I am not sure it is 20% buffer. The extended range have 88 Kwh usable but it is a 99 KWH battery. They have slightly over a 10% buffer.
DK922
Dennis
2021 Mustang Mach-E Premium AWD
It's an issue with the GPS location. When I'm at home, it shows my location as 5 houses down unfortunately, so it doesn't use my "Home" settings which are set to charge to 90%. Instead it charges to 100%. Annoying...
