Signature Light Removal
Pioneer74
Dearborn
2022 Lightning Lariat ER - 2022 Mach-E Premium
I have a current unscheduled order in for a Premium ER. I also have access to Vehicle Visibility.
Looking through my order details I found a recent entry. "Signature Light Removal". There is a Premium at my dealership in front of my order scheduled to be built in September. This order also has it. There is a GT after mine. It also has it. In the Order Guide, Signature Lighting is referenced under the headlamps.
Get ready for more decontenting on the fly.
BigMach-E
Bay Area
Mach-E GTPE Shadow Black 2021
Prices (likely) going up, items being removed. Is the signature lighting the light up badge or the puddle lights?
Pioneer74
Pioneer74
Dearborn
I'm not 100%, but I believe it's the daytime running LED in the headlamp.
I would be very annoyed if the signature lighting was removed. That likely means no LED headlamps either. You’re probably going g to be stuck with crappy projector headlamps.
sotek2345
Tom
Upstate NY
Engineering Manager
Unless the lights are the same and they just don't have the control chip for the signature lightning LEDs.
I would hope it isn't the projectors, or that Fords gives a big discount for the deletion. Those LED headlights are wonderful!
Efrain
Efrain
Mustang Mach E,
The Mach E Selects have Led headlamps without the signature bars.
MY21 J1 Premium RWD SR
Right. All of the existing Mach-Es have LED headlamps and taillamps. The difference with the signature headlamps is they are projector style instead of reflector style, and they have the Mustang-signature tri bar look and signal wipe animations.
Jax_GT
AZ
2022 Mach-E GT (Build in progress)
This would be a real bummer. A lot of brands go with unique running lights to tie models together or define a signature look for the brand. Guess 'signature' means something else to Ford.
captcrunch11
Nick
Mach-E Premium Standard Range RWD
How much do you think this saves Ford? Maybe $40 per car? This is on the GT and & Premium trims, so they are already higher margin vehicles.
It‘s more likely related to chip or parts shortages than saving a few bucks.
