RobbertPatrison
- Mar 24, 2022
- Silicon Valley, California
- Ice White Mustang Mach-E
I notice that my Ford mobile EVSE charging cable cannot sustain the rated 32A (7.6kW) for long. After about 15 minutes the yellow light comes on periodically and it throttles back to 20A. And then it starts oscillating with a period that changes over time. Here is a plot of the power usage when charging over a 45-minute period. You can see it flip between 32A and 20A constanty:
In some cases, it switches down from 32A briefly to 20A and then to 12A, and then back again. All in less than a minute:
The result is that the effective charging speed is significantly lower. Here is what I suspect is happening:
The problem seems worse when it is warner, which is consistent with the temperature sensor triggering the events. In a 60 degrees garage at night, I got about 16 minutes of 32A before it started oscillating. When the garage is warmer the problem begins earlier.
The EVSE itself does not seem very hot. I took this picture with an infrared camera. You can see that the hottest part of the EVSE is 28C, and that the bottom cable is warmer than the top endthat connects to the wall plug. That is likely because the longer cable is 12AWG and the short end 10AWG.
There are some possibilities:
- The EVSE heats up internally at 32A
- The EVSE tells the charger in the MME to throttle down
- The EVSE cools down a little
- THE EVSE tells the charger in the MME to throttle up again
- goto step 1
- Throttling back is a 'feature', meaning the EVSE is not really designed to sustain 32A charging. But in that case, it would have been better and safer to always cap the charging speed at a lower rate, rather than this silly oscillation. The cable appears to be 12AWG, which is thin for 32A.
- Many others reported slow charging or the yellow light coming on. So it could be a design flaw causing overheating.
- This could be my EVSE with a defective temperature sensor, or a bad contact. I might have to claim this under warranty. In my 10 years of driving electric, I have never been back to the dealer for a service issue. So that would be a first...
