So, I received the second update, and I gotta say, I’m not thrilled…
JoeDimwit
Waterford
Grabber Blue First Edition
Electrician
I noticed yesterday that my drivers window (and ONLY my drivers window) no longer can be closed with one touch on the window switch. I didn’t think much of it until the behavior continued today. I went to the shitshow that is FordPass, and wouldn’t you know it, “Update Successful- Check What’s New”. Somehow, I don’t see this as an enhancement of the quality,capability, and convenience of my vehicle.
anyway, is anyone else experiencing this particular enhancement after update 2?
NewRadiant
Matt
Suki0627!
20201 Mach W
Analyst
I noticed this too! Started yesterday, got the ota notification last night. I was so confused! Hopefully this particular "feature" is remedied quickly
JCHLi
I'll check later, but it's there a setting that can be changed to allow this? Did the update but make this a configuration option that wasn't there before?
crazyfool54
AJ
VA
Mach E FE GB
I thought I was going crazy when this happened to me! I actually had this happen a couple weeks ago but only for a few days. It eventually fixed itself. I got the second update this morning so mine was not related to this update.
I had this problem a while back. Not sure if it was related to the update though.
There is a procedure in the manual to re-train the windows. Normally required when 12v power has been disconnected for a batter change etc.
Give that a try.
Sorry, I don't have a handy link at the moment...
JoeDimwit
JoeDimwit
Waterford
Electrician
Give that a try.
I will definitely get into that. Thanks for the suggestion.
JoeDimwit
JoeDimwit
Waterford
Electrician
I’m sure that this is a possible explanation, but I find it odd that the other 3 windows would be unaffected. I did try all 4 windows before posting this thread.
My car was delivered with both OTA done. No issues with the windows.
Page 105 of the manual has the resetting the one-touch close procedures:
Ford Mustang Mach-E So, I received the second update, and I gotta say, I’m not thrilled… 1620836393417
JCHLi
Yeah it is odd, but not based on the helpful info from the manual, I'm thinking this might just happen from time to time (at least often enough to put a resetting procedure in the manual).
Seems unrelated to the OTA other than potentially a setting might have had a knock on effect of disrupting the window control.
RonTCat
Ron
Mach-E wannabuy
The weatherstripping or flocking for each door window seal is never as "sticky" or "slippery" for every window, and there is no "window position sensor", so the system looks at the window motor force to determine when to "stop trying to close the window". The friction needed to move the glass up and down may have changed from "default" on that one window. Maybe you use that window the most. Normally, you inadvertently calibrate this away all the time without knowing it by holding the window button just a few seconds longer than needed to fully close or open the window. The update might have reset all the calibration update values. If the window seal is a little "stickier" now, the system default might interpret this increased friction as "the window is closed now". The calibration procedure should fix it.
MachE1977
SoCal
18 Tesla Model 3/ 2020 Mazda Miata Club
This happened to me a week or so ago. I don't remember if it coincided with an OTA update. However you can fix it using the procedure that was linked above.
Great thing about EV's just reset everything! This happens with other EV's also.
Luke
Luciano
MA, USA
Mustang Mach e, Taurus
Computer Engineer
Yep. Got the two OTA here too. After each one, I had issues with both PaaK and Carplay. I had to reset the connections by removing and reading the phone. I hope that does not become the new norm. That way PaaK will never be reliable.
JCHLi
This answer is far too reasonable and well explained for the internet!
Just kidding, thanks for the detailed explanation!
JoeDimwit
JoeDimwit
Waterford
Electrician
I reset the One-touch closing on the affected window, that has solved the issue for me.
thank you SnBGC for the suggestion, and thank you Kamuelaflyer for digging that procedure up out of the manual while I was still at work.
