available_username2
So what does the button by the charge port do?
Only for DCFC charging.....not used for AC charging.....So what does the button by the charge port do?
Does your FCCS connector not have a thumb button?When I charge at home using my FCCS, I have to press the button before it will release the plug.
It does have a thumb button. Now I'm doubting myself. When I charged the first time, I swear it wouldn't unplug until I pressed the release on the car, so I've been doing it ever since. I'll check it again.Does your FCCS connector not have a thumb button?
The Ford Service Manual says that button is for DCFC only.......but there isn't anything saying that pin can't also lock in the J1772 connector if the car chooses. ?
If that lock pin is activated.....then it would not allow your thumb button to operate mechanically, it will feel like its locked or something is blocking it. Ford redesigned the lock pin for the MME. I compared it to my FFE and it has a different mechanism. Comes down from the top. The MME comes out horizontally (if I remember correctly.....)It does have a thumb button. Now I'm doubting myself. When I charged the first time, I swear it wouldn't unplug until I pressed the release on the car, so I've been doing it ever since. I'll check it again.
What charger do you have? I have a Grizzl-E and I find that I need to push the button to get it to release.It does have a thumb button. Now I'm doubting myself. When I charged the first time, I swear it wouldn't unplug until I pressed the release on the car, so I've been doing it ever since. I'll check it again.
FCCS = Ford Connected Charge StationWhat charger do you have? I have a Grizzl-E and I find that I need to push the button to get it to release.
Try it again, but without pushing the button first.What charger do you have? I have a Grizzl-E and I find that I need to push the button to get it to release.
I just wanted to update this topic. I charged last night using my FCCS. I definitely could not remove the connector without pressing the button on the car.It does have a thumb button. Now I'm doubting myself. When I charged the first time, I swear it wouldn't unplug until I pressed the release on the car, so I've been doing it ever since. I'll check it again.
Interesting. Have you charged from other Level 2 EVSEs? Is the FCCS the only one that locks the connector?I just wanted to update this topic. I charged last night using my FCCS. I definitely could not remove the connector without pressing the button on the car.
I have not, but when I do, I'll report back.Interesting. Have you charged from other Level 2 EVSEs? Is the FCCS the only one that locks the connector?
