Mirak
- Oct 8, 2020
- Kansas
- "Sonic" 2021 MME Grabber Blue First Edition
I hope at least a few others with similar frustrations find this helpful. I had a call with a Ford engineer today, and he explained why I cannot keep the interior motion sensors turned off.
TL/DR: It is NOT a bug. Just poor design. But maybe a design that will be improved in the future. [UPDATE - well, maybe even the way Ford designed it is buggy!]
First, the issue: my kids or dog frequently set off the car alarm when they get into the car before I do, or if I step out of the car to run into the store, commence a public charge, etc. You can temporarily avoid that by enabling “ask on exit” to manually deactivate the sensors every time you turn off the car [UPDATE: I can now confirm that even this doesn’t work consistently according to posts below and it has now also happened to me] but that’s a little annoying. So I had hoped to permanently disable the motion sensors in the menu. Under Setting > Vehicle > Alarm you can turn Motion Sensors On or Off. But if you toggle them to Off, they still revert back to On each time you restart the car.
I thought this was a bug. It is not. It is just poor design. Or, to be more specific, old design that doesn’t take into account newer functionality. Here’s what I mean….
When the engineer took my issue back to the team, they didn’t understand what I was doing. They said (paraphrasing): “Why is this an issue? The motion sensors are only active when the car is locked. So how are people getting into the car before him? And why is he locking kids / pets in the car?”
Ok, put aside that sometimes you might want to lock your kids / pets in the car - the engineer explained that my issue is PAAK and the “walk away lock” feature. The car unlocks when I’m close by, allowing my kids to get in, and locks when I walk away, with my kids still in the car. And then the alarm activates. The motion sensors were not designed to be permanently disabled because, back before PAAK and the “walk away lock” functionality, it wasn’t nearly as much of an issue.
He said the solution was to disable the “walk away lock” feature, and either don’t lock the car when kids or pets are inside, or manually disable the sensors each time I do leave them inside.
Ok. So first I agreed with the engineer on his diagnosis and conceded that this was deliberate design and not a bug. But I then explained that it is poor design for several reasons:
So good news and bad news. Bad news is this isn’t a bug that will be fixed anytime soon. [UPDATE: more bad news is that even temporarily disabling the sensors doesn't always work] Good news is that I’m guessing we’ll eventually get a good workaround with a future enhancement of adding safe zones.
AND FINALLY, if you think covering the sensors with tape will do the trick, think again. I've covered my sensors and my kids still occasionally set off the alarm because apparently the sensors are also triggered by rocking, and it doesn't take very much.
- It’s confusing. If you cannot permanently disable the motion sensors, why even include that toggle 5 taps deep into the menu? Nobody wants to go that deep into the menu every time (and I understand you don’t have to if you enable “ask on exit” but that doesn’t eliminate the confusion of the motion sensor toggle deep in the menus).
- There are rare instances where you will want to lock kids / pets briefly inside the car.
- The “ask on exit” is not a suitable workaround because it is cumbersome having to engage with that every time you turn off your car. [UPDATE - and even that doesn't reliably turn off the sensors!!]
- If your car is locked with the windows down, such as possibly in the garage, you can easily set off the motion sensors just by walking too closely to the car.
- Disabling “walk away lock” is not a viable workaround because that is a very useful feature (most of the time)!
- Allow the motion sensors to be permanently disabled, and/or
- Allow “safe zones” to be set, such as a home garage, where walk away lock does not trigger (this is a feature already included in the Super Poll).
