dbsb3233
- TimCO
- Dec 30, 2019
- Colorado, USA
- 2021 Mustang Mach-E FE, 2023 Bronco Sport OB
- Retired
This has been an ongoing issue discussed in other threads, and I thought it deserved it's own thread.
The problem is getting into the car and finding that 2 of the 4 sound settings always revert back to their default setting: TONE and BALANCE. Oddly, SPEED COMPENSATED VOLUME and STEREO/SURROUND seem to work OK.
I've done a lot of testing this morning trying to nail it down. It turns out that the TONE and BALANCE setting are actually saving to the driver profile, but for whatever reason they're not kicking in when getting in the car. It's detecting the right driver, per the avatar at the top of the screen. The seats and mirrors are moving correctly to match that profile. As are the radio/SXM presets, etc. But for whatever reason, the TONE and BALANCE settings aren't getting implemented from the driver profile.
One way to confirm that is to manually switch to a different driver profile via the 1-2-3 buttons on the driver door. When I press #3 it switches everything to that profile, then I hit #1 and it switches back to my profile, with the correct TONE and BALANCE. So manually switching it to a different # then back to #1 is a workaround for now.
Another workaround is to turn Personal Profiles OFF altogether. That's what I may do until this is all fixed. I have to set a bunch of other settings now too that were tied to my profile, but since I'm the main driver and we share most the same settings anyway, that may work best. Looks like the seat and mirror settings will still automatically change according to which fob is used (maybe PAAK too but I haven't tried that).
I don't know if just some cars are having this issue or all of them. I know others have mentioned it too. If you're having that problem, try switching to a different 1-2-3 door button, then back, and see if that works. Curious if others are finding the same thing.
