shutterbug
- Joseph
- Nov 5, 2020
- AZ
- Joseph
- C-Max Energi
https://evcharging.enelx.com/store/accessories/juicebox-adapters-input-cablesIt says that under the Juicebox EVSE column, not for the adapters.
How could an adapter that allows a device using a 50A plug to connect to a 30A circuit pass certification?
These adapters connect plug-in JuiceBox 32 and JuiceBox 40 electric vehicle charging stations to common household outlets.
- This product is designed specifically for use with JuiceBox electric vehicle charging stations, and may not work with other devices.
- Please be aware of the capacity of the receptacle you are plugging into. When charging with any of these adapters, JuiceBox will charge at reduced speeds. Depending on the capacity of your circuit, adapter use may require setting a lower charging rate in the EV JuiceNet app.
- Always consult a certified electrician when working with high-power electrical equipment.
- Made for indoor/outdoor use.
