- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
EDIT: This has been replaced by SSM 51783. The fix timeline has been delayed further from June to August.
SSM 51513 2021-2023 Various Vehicles - High Voltage Battery Stops Charging With Illuminated MIL And DTC P2C94 Stored In The SOBDM
Some 2021-2023 Ford and Lincoln vehicles may exhibit a condition where the high voltage battery stops charging when connected to level 1 or level 2 chargers with an illuminated malfunction indicator lamp (MIL) and diagnostic trouble code (DTC) P2C94 stored in the secondary on-board diagnostic control module A (SOBDM). To restore charging capability, disconnect the off-board charging station charge handle from the vehicle charge port and reconnect. This condition does not affect vehicle durability and no additional diagnosis or service is required for this condition at this time. Inform customers that they can continue to drive the vehicle and engineering is currently working on a solution for this condition that is expected in June 2023. Replacement of the SOBDM will not resolve this condition. Monitor OASIS for additional information.
----End SSM----
P2C94 - Hybrid/EV Battery Contactor Control Supply Circuit Low - Sets when SOBDM senses the contactor relay control circuit voltage is low while the contactor relay is being commanded open.
When the ignition is off and an EVSE is connected to the vehicle the SOBDM sends a signal via low side driver to close the contactor relay located in the BCMC. The contactor relay sends a 12-volt supply voltage to the BECM and the high voltage battery junction box. The SOBDM monitors the contactor relay control circuit voltage to determine if the voltage matches the SOBDM command. If this feedback voltage does not match the command Close - Low or Open - High DTC P2C94:00 or P2C95:00 sets. If DTC P2C94:00 sets the SOBDM terminates or does not initiate charging of the high voltage battery and the Charger Service Required indicator in the IPC is illuminated.
Basically this seems to be some sort of timing glitch, the circuit may already be low from the SOBDMC commanding the circuit ON/closed, which confuses the SOBDM and induces a charge fault. If you get a fault while charging, try unplugging and replugging the J1772 handle and watch the indictor lights (should turn blue immediately). If that doesn't fix the issue, try a high-voltage reset: https://www.macheforum.com/site/thr...ng-service-vehicle-soon-while-charging.26983/
----End SSM----
