- Steve
- Mar 23, 2021
- Bay Area, CA
- 2024 MME GT with Performance Upgrade, 1979 Fire-Am, 1972 K/5 Blazer
- Engineering
The problem doesn't have its root in a "deeper charge." It's in chemical activity within the battery. As the battery's temperature drops, the chemicals become more sluggish resulting in less ability to hold and deliver power. Were you able to achieve a higher electrical capacity while the battery is warmer, it would simply fall away as the battery is cooled while driving. Preventing that heat loss is more practical and effective. At this point there isn't enough ground clearance to create an effective enough insulation barrier.I’m not too concerned when driving, my thoughts are geared more to getting a deeper charge as I do in the summer months. My thinking is if the batteries could be heated independently while charging perhaps less energy would be wasted in heat putting more energy into the battery charge. I could be overthinking this and maybe it’s not worth the effort. —as for losing heat while driving maybe covering up the radiator partially or even fully may help. I’m new to the forum so maybe this has been suggested. This site seems to be a busy place with loads of info.
